By ranchhelper
VinDecoderz says it's a YFM350 (Moto4 350) trim YFM350ER
Is that a Big Bear? Or a Moto 4? Or are they the same thing?
I've google'd around for information, and was able to find a (czech board in english) that had a Yamaha service manual for the YFM350X series, LIT-11616-YM-37. The 'Warrior' type. I'm trying to get something more accurate. I'm not sure which manual I need. Pictures included in this post.
I'm also looking to get a wiring harness for it.
By Ajmboy
By Spritee1
not sure where to look next
By Ajmboy
Anyone purchase or check out Rockymtnatv lately? Well I was just browsing over there and they have a pretty cool section called Ten Dollars Or Less. Some interesting things to check out if you are in the market.
By Johnfj44
The stock driver seat cushion is separated at a seam. I took the seat apart and found that the material has torn and cannot be re-stiched. I'm trying to find a replacement seat. Any suggestions? Hoping for a used seat but couldn't find one on Ebay.
