1988 Kawasaki 220 Bayou trying to remove generator/ starter 1way clutch cover to be able to replace 1way clutch. All bolts are removed case cover is dripping what oil that remains...but I can't get the cover to come off..what am I missing? Thx in advance.
Edited by Monika Novakov
Spelling
Welcome to Quadcrazy @Monika Novakov I’m not sure what you mean by the generator/starter ? Do you mean the left side engine cover?  The starter should be removable with a little bit of wiggling without taking that cover off. You can remove the left side engine cover to see what’s going on with the bendix/one way clutch depending on the year/model and see how it’s all operating and if anything is wrong.  If the cover is sticking maybe a little tap with a rubber mallet will help.
Here’s a YouTube video of a 250. Should be pretty much the same.
    • By HoldenBoy
    • By crankin
    • By marlon smith
    • By quadnut20
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
