2006 Yamaha Grizzly 660 water line connection
By middlebrookgt
By Gwbarm
By Ejwill
By nblain
Sorry, bit of newbie question on Honda TRX520
Can anyone tell me if it is necessary to drain the engine oil to just remove the oil filter cover?
I recently carried out an oil change and when checking afterwards, found oil leaking from around the oil filter cover (was torqued to 10Nm). I am going to get new O rings to be on the safe side, but was wondering how high the oil level in the engine sits relative to the pump filter and do I have to drain the oil?
TIA
Nigel
