Thanks Frank
I found while starting to pull the buffer/balance drive gear that outer edge of the gear moved out far enough to get the chain by it without dumping all those lovely little springs. I had also removed the tensioner side chain guide.
I stuffed the timing chain in, put the balance gear and plate back in place and done. Somewhere I found that that the old camshaft gear compression weights were just pressed in, and swapped them onto my new cam gear.
Nice work, be sure to use plenty of grease so you don’t have any crazy friction during initial start up. Maybe change the oil one more time after break in. Hopefully everything worked out good and your ready to roll.
Ride safe.
    • By Yamahahahaha
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
    • By Damien911
      Setting the timing on a 2005 Yamaha 250 Bruin
    • By Thebritish
      My bayou 250 came to a stop and would not not start, it turned out the starter clutch had a fit and died. I changed the starter clutch which had sheared off the 3 bolts attaching it to the flywheel and everything went smoothly. However, when I went to start it I found it would not start. On investigation I found the timing out of whack, by alot. Thinking it was something I did on the repair, I repeated the process of removing and reinstalling the starter clutch and related components and resetting the engine to TDC. Tried to start and immediately realized the timing was out of sync again.
      Is there something I'm missing? Could there have been a bigger issue, possibly on the other side of the engine? I don't understand why, with a brand new starter clutch there would be such movement in the crank. The timing chain and sprockets do not look worn and appears to be tight on the tensioner. When I move by hand everything appears to move as you would expect. But when I try to start it using the starter or the pull start it goes out of whack!
