Resistor vs Non Resistor Plugs/caps
By Eisenmatt17803
Good Morning!
Thanks in advance.
By Malta54
I own a 2007 Polaris Sportsman EFI X2 model and have for the past months been experiencing loads of issues. Basically the Sportsman will only start if the throttle lever is pushed and will not remain on idle. This situation has persisted for months now and I have replaced the following parts:
Sparking Plug
Fuel Injector
Fuel Pump
Fuel Filter
Fuel Valve
Fuel lines
Power Control Module
The last part replaced was the Power Control Module and the Sportsman was tested and worked fine on a couple of occasions which were days apart so much so that some weeks later I took the Sportsman for an extensive ride and it worked perfectly. This was three weeks ago and today I tried to start the ATV it worked fine a few minutes and decided to switch it off so that I could continue with some prep work. A few minutes later tried to start it up again but noticed that it would only start if the throttle lever was pushed and once I removed my finger from the throttle lever the engine would not stay in idle and would simply shut down. Several attempts were made to start this and also tried to re-adjust the setting by turning the built in wheel like mechanism in the throttle cable but it was to no avail.
The above have been repeating itself on an off basis. Each time a part is replaced the ATV would work and then all of a sudden will not keep its idle. At this stage I cannot think of any other solution other than possibly some sensors which might have an intermitting fault but I cannot really say.
Would greatly appreciate any assistance.
Thanks in advance.
By Suzukiquad
Are there any good mods for adding a radio, or Bluetooth speaker that's kid friendly? My son thinks he needs music while riding around.
By prdicon
Hi
Are you using any spray to prevent mud from sticking to the ATV.
Both plastics, and engine.
By Hermi
I have this ATV that was given to us by sister inlaw...and look like the fuel filter fell out when drive around....but i can find anything on that system. if anyone could be soo AWESOME to please post manual and/pr pick of where the fuel filer goes that would b GREAT!!!!
Thank you all for any help!!!!!!!!
