I would see about adding a fire extinguisher if you don't already have one. If there is no recall, the manufacturer deems it safe. There have been a bunch of RZR fires from what I've read. Something like:
https://amzn.to/2J1iZrx
  • 2 years later...
    • By Brute
      2012 brute force 750.Imused it one day to pull my mower from the edge of my tank.I pushed it hard enough to break the front actuator.It ran fine until the next day,now it won’t start and the check engine flashes while cranking.I checked all fuses.Had a rat chewed some wires.repaired them.done everything I know to do.coils have fire with test light.help
    • By p5200
      I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
    • By Bdubb0227
      Hey guys, I'm new on here but I have a hell of a problem.  I traded for a 98 timberwolf 2x4 and it ran good but smoked.  So I decided to get piston and rings with new jug a and put everything together did the timing by the marks on the fly wheel and the cam gear and now all its is rolling over in the back fires extremely loud someone please help
    • By rgeiser
      just wondering if i pay the thirty dollars how soon will i be able to access the manuals?
