Similar Tagged Content
By Bobby_Rickard
Replaced battery, relay and starter. Turns over and starts part of the time and other times just rapid clicking.
IMG_2753.MOV
By Denis Lanthier
Hi All,
I have a 2004 Yamaha Kodiak, which has taken me to many remote places and hauled lots of game. I still love it after 16 years.
Lately when I go to start it using the starter, sometimes it clicks and kills the power in the display. Lights don't work, nothing works and I end up having to unplug the battery, wait awhile, and replugging the battery ends up giving the power back. Using the winch will sometimes kill the power as well.
Battery is new, all fuses are ok, I'm at a loss. I can start it with the pull crank and it will work and so will the lights.
Any insights or advice would be appreciated!
By Ajmboy
Disconnected the plow yesterday on my 2004 Yamaha Grizzly 660 and am getting ready to do some riding yesterday and the battery went weak, Starter cranked a few times but week. Put my trickle charger on that I bought and went to the garage today to start it up, but the starter is just spinning and not engaging. The solenoid is clicking. The pull start sucks and is hard to pull (never use it and need to look into that). Quick video of the starter spinning. Could it be the starter or the starter clutch one-way bearing? I guess I need to take the cover off to see what's going on.
2004 Yamaha Grizzly 660 Starter Spinning.mp4 -
By Milsparro
Howdy y'all. Just bought myself a 2004? Yamaha 400 with electrical Gremlins aplenty. Runs good (after jumping the starter solenoid relay terminals with the helpfully included with the sale pliers) but no fan when my wife's 03 Kodiak 400 had fan and the starter button makes it to the starter solenoid but the ECU side isn't happy. This seems to be a lively forum with manual downloads being supported so hi.
Oh yah, and you can get two Kodiak 400s on a 5x8 trailer... I bought a nice 14' trailer as soon as possible after this.
By Jay Reddick
Hey guys, need some help with my 2016 Yamaha Kodiak 700 4x4. Was riding and it started smoking below the air box and then Caught fire. We got the fire put out quickly with a fire extinguisher. Many of the wires below the air box got damaged. I purchased a new wiring harness for the atv and replaced that as well as any other damaged cables or parts that burned up where the fire was. I also replaced the regulator, the ECU, and the starter solenoid. I also replaced the stater since some of the cables that went to the regulator were damaged. It acts like it will crank but it won’t turn over. The fuel pump initialized when I turn the key so it’s working. I’ve spend $1500 on parts and no luck yet. Any suggestions?
Similar Topics
By Asen_77
Hi All,
My name is Asen and I am from Eastern Europe, Bulgaria. Riding a Yamaha Raptor 700R and this is my first Quad wanted for a vey long time :)
By Leski991
Hello,
I have read many forum topics on this matter but have never found a similar problem. So i bought a cheap ass quad thats got all sorts of parts on it. It's a 1997(if you look the date on frame) Kawasaki KLF(Bayou) 300 EUROPEAN Model (atleast I think, since I'm from Europe), the engine is 1988 if I'm not mistaken and the CDI is 1995.-2006. ( 21119-1447, 6pin ). My problem is that I don't have spark. I would diagnose the issue but connectors from CDI to wiring harness have almost all different colors and I'm not sure if they are connected correctly (pictures below). Pickup coil is putting out around 400 ohms and is pulsing. CDI is being fed 12v by one y/r wire that is coming to connector and with 12v to one gray wire which is coming from ignition switch ( quad actually doesn't have ignition switch so I'm not sure if gray should be supplying power or not). Stator looks good cause when crancking all three yellow wires put out around 5v AC. Neutral light is also on which means the switch should be ok, if it even matters. I know it's not the ignition coil since I get no power nor any kind of pulsing to G/W wire that is coming to it ( and I even put another one on there just to check an it ended with the same result). I'm nowhere near proffesional around this type of stuff so any help would be amazing.
By Jride937
Have a 2002 Yamaha Bear tracker 250, everything was fine then one day just lost power. Battery is fine, have 12.53 volts coming out, but I have no lights no start no anything. Looking for a wiring diagram
By wiwild
Hello everyone !
I'm currently rebuilding my carburetor on my Yamaha moto 4 350 1987, first time I rebuild a carb 😅 ! It was leaking fuel from the overflow and inside the intake ....
When I took off needle (the platic top part was stuck like crazy) I had a spring and inside the kit there is a spring, an O-Ring and a washer.
Left is the needle that was in the carburetor and right is the new set (I already tried to mount it but it didn't felt right and I accidentally broke the o-ring)
Anyway, I saw in some videos and diagram that there is no spring in here. So should I put the spring back ? And where ? On top of the needle or bottom ?
This is an original Mikuni carb :
Thank you ! Also if you have any additionnal tips please feel free to share I want to learn the proper way !
By JacobSlabach
Hey just picked up another scrambler 850 was told the tps was bad. This atv has been beet to hell. Wiring has been tinkered with the crankcase has been replaced recently and the motor rebuilt (can see horizontal scores thru spark plug hole where it’s just been honed out and rebuilt)
my guess is it was ragged out till the motor blew a rod and rebuilt but the clown that did it couldn’t get it to run again and sold it. When I bought it it would pulse and smoke black at idle and die with throttle.
New tps installed and it won’t run period. I went to celebrate it and I’m getting 5 volts on 2 of the 3 wires running to the tps. Is this normal and if so how should I celebrate it?
