2003 Raptor 80 shifting problem
Venom
Hi All,
I did a total restoration on a 2003 Yamaha Raptor 80. Rebuilt the engine and tranny.. Started it up today and it runs great. Took it for a ride and the transmission worked perfectly. Adjusted the carb a little more and went for another ride. It ran awesome, pulled into the workshop shifted into neutral ( Neutral light came on) and shut off the bike. went to roll it and noticed she would not roll. Turned on the key and neutral light was on... After some troubleshooting I found that she is in first gear with the neutral light on and will not shift into neutral... It seems to up shift fine into 2nd and 3rd and then back down to 1st. I am hoping somebody can shed some light on what is happening... Thanks for any help...
Ok , got the motor out.. Took off the clutch cover. The shift shaft is working properly and all springs are intact and working properly. The shift cam assembly seems to only be turning between 1st and 2nd gear. No neutral or 3rd gear.  Next I will disassemble the engine and split the case.... It would have been so nice if it was a spring..... More updates coming...
Once I split the case and was manually trying to go through the gears by hand I could feel it binding up... I took out all the transmission parts and inspected each one according to the service manual. Everything was fine and in spec. I reinstalled everything and the gears changed like butter, as they should. Something has to have caused the issue... I need to really look at everything....
Luck was on my side....  While inspecting everything while the engine was in Neutral I grabbed the case and main axle shaft to move the engine for a better look and low and behold it was no longer in Neutral even though the transmission had not changed gears...  After gently moving all the transmission parts in every direction looking for slop I found a slight movement of the Main Axle Shaft. It was sliding about 1/8" left and right. This was enough to engage 1st gear and Neutral..  Upon further inspection I found that the plate that holds the Main Axle Bearing in place had come loose and the bearing had moved out 1/8" creating the shifting problem.  I tightened the plate back up and no more shifting problem.  The two screws that hold in the bearing plate had been torqued down according to the service manual. This time I added Loctite before torquing them down. Just in case this ever happens to anyone else I have added a photo showing the location of the Bearing Plate. It sits behind the clutch... That is correct... Behind the clutch... If I had initially seen that I would not have had to split the case... 🙄
Edited by Venom
47 minutes ago, Frank Angerano said:
God forbid it should be something simple. Looks good and clean and a clean work bench/work area, that's important.  Let us know what you find. Did you order new gaskets or were the old ones salvageable?
I may have been able to salvage the gaskets, but I decided to play it safe and get new ones..  I have a post on here about the complete restoration of this Raptor 80. I have been slacking on adding updates, but have all the photos and will update it soon..  https://www.quadcrazy.com/atvforum/topic/14419-2003-yamaha-raptor-80-restoration/
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By HSTAR
    • By ResQ91
      Hi guys
      battery and connections good
    • By jatho
    • By McG75
