STOLEN ATV: Stolen ATV
Similar Topics
By Olds4428872
I have been looking for a parts Manuel so that one I have a list of parts an two so I can find the parts to replace what I need. I know that the patient was sold to John deere but when I call them to get the parts they tell me I need to have the parts numbers so that they can match them but my atv still runs an drives I just don't want to have to tear it down an have it be down till I get the parts. Can anybody help
By Travis Waller
We just bought this about 2 weeks ago and the chain keeps popping off. I’ve dealt with 4 wheelers in the past but nothing with this chain setup.
By Bryzan3
Looking for advice on what to try next I bought this quad and it’s has spark and fuel but won’t stay running only fires when I hold the starter button in even when spraying gas into the carb it still dies right away oil was milky white so I was thinking it maybe went under water 150 psi compression so I might be wrong but not a head gasket I am stuck Cause it should stay running with the straight gas through the carb so what should I try
By ATVNetwork
news How a recreation staple met its untimely demise.
FortNine pens a loving tribute to the three-wheeled ATC, and asks: What really killed them? View the full article
By cfauvel
ok help so according the service manual, Idle Air Mix Screw (aka Pilot screw) should be initially set to 2.5 turns out from fully seated.
If I do that the motor doesn't want to start or stay running...right now the pilot screw is probably somewhere near 5 turns out....I'll take the carb off tomorrow to count to know for sure.
mind you the carb got a new float seat,float needle and various other components in the kit.
To get the motor running I hard to turn the pilot screw out quite a bit, and turned the idle speed screw in quite a bit...I didn't hook up an inductive tach to know what it is idling at, but does sound about right.
What should the idle speed adjustment screw initially be set at (the one that has the black cable sheath with a knob you can twist easily)?
Is there a special tool to turn the idle/pilot mix screw whilst the carb is on the running motor? I am using a slotted screw driver bit (normally goes into a driver) by hand..makes it hard to turn the driver and hard to tell how many turns .
