There's an online copy of a service manual for a Z400 in the other atv forum I post on.I know you have a Honda but the measurements are the same;with different settings/specs.Here's a link ATV Forum Website. ATV. ATV News ATV Reviews Kids ATV ATV Parts ATV Forums The correct settings/specs should be in your owners manual.You can check to make sure both sides are straight by using a tape measure.Measure from the inside of each steer tire to the frame.Hope this helps
My only worry is that my tape measure only reads in sixteenth of an inch, the tool that Honda uses goes down to a thousandth of an inch.
Measurement isn't everything. Sometimes test and play works better. Did that with my Ozark.
The thing is I rode for the whole day and thought the dirt was real loose. Got back and realized that my right tire was pointing outward. So I don't really notice that stuff, probably should but I don't. I'm getting new tires soon and I don't want them to wear funny. I think I will suck it up and drop the bucks.
Factorary specs have a slite toe out. Just telling you this so it does not scare you.
  • 3 months later...
It is that easy. But start by making sure your handlebars are stright ahead then sight down the right and left and make sure they look like they are pointing straight ahead. Adjust if nesseccary. Then take the measurments. You want around 1/4" toe in.
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
    • By treycotiii
      Looking for the best options. I primarily use the machine for snow removal and yard cart pulling.
