Starting problem 2004 Suzuki Twin Peaks
By HSTAR
By ResQ91
Hi guys
battery and connections good
By HoldenBoy
By p5200
By Scoopeddad
I have a 1994 big bear and I am starting to have issues starting. I put in a new starter and selnoid as the at stopped starting with the electrical but will still start with the pull cord. Where and what now should I be looking at to check? If I turn key to on and the switch to on then hit the start button, the bike clicks and then nothing. Lights still work but no response to the starter. Stumped now. Any help would be greAt.
