Starting problem 2004 Suzuki Twin Peaks
By HSTAR
By ResQ91
Hi guys
battery and connections good
By p5200
By Scoopeddad
I have a 1994 big bear and I am starting to have issues starting. I put in a new starter and selnoid as the at stopped starting with the electrical but will still start with the pull cord. Where and what now should I be looking at to check? If I turn key to on and the switch to on then hit the start button, the bike clicks and then nothing. Lights still work but no response to the starter. Stumped now. Any help would be greAt.
By vlxerdon
Hello from southeast Georgia. Was gifted a 2000 Yamaha bear tracker with out a carb or battery and looking like it had seen better days. Was told it had sat for about three years. Explained a lot. Put a carb on and a battery in and it started right up. Surprised the heck out of me Anyhow as stated in my opening I am 78 years old with a very long motorcycle backgground but brand new to atv's. Anyone else out here from Georgia? Would like to meet up with some folks for a ride or two. Looks like a great site. Thanks for having me.
Don
Similar Tagged Forum Content
- 0 replies
- 3,544 views
- 3 replies
- 5,132 views
- 10 replies
- 4,531 views
2000 Yamaha Bear Tracker 250 neutral light and ignition not working
By Stacy Hanks,
- bear tracker
- neutral
- (and 2 more)
- 2 replies
- 9,577 views
- 5 replies
- 3,323 views
