Ozark 250 Carb Question
Drilled into the carb or on the bottom side of the carburetor to expose the air/fuel screw?
Or the actual inside of the bowl where the main jet is ?
It's common to find the bottom of the carburetor drilled out where the air/fuel screw is. Certain states mandate that the screw be factory set and covered for emissions reasons.
I pullled the carb again in fustration, double checked all passages etc. Put it back together and it runs but at idle it has occasional back firing through carb. I set idle screw at 2 1/2 to 3/4 turns. Also have to make out idle knob. Files fine and  revs fine, even has power riding it, just keeps popping in the intake?!?!
I think your seeing that wrong, that is the bowl. The idle air screw is on the left side of the carb
Yea it looks like someone started and then stopped drilling, almost like they thought it was the idle mixture and then realized it wasn’t. I’m still having the same issue, it’ll crank and idle. I have the idle mixture set but have to crank the idle adjuster all the way down to idle, and has a pop in the air box and sometimes will just die. Ha plenty of power and runs out fine, but I can’t for the life of me figure out why it’s popping and occasionally dieing!!! I check valve clearance and intake is a little on the high side around 0.005-0.006 but I don’t think that would cause it? Will adjust when I find my correct feeler gauges. I just bent a 0.007 and I can cram it in there. So I know it’s larger than tolerance allows.
That plug is the main jet. If the jet isn’t seated on properly it will allow gas into the carb causing your backfire. Fix that jet. Your float can be right but even with the float closed. It will still dump gas in. Close the float while it’s apart. Hook an air line to the carb and blow into it. If not. Look into the float. Improper float heights and bad seat gaskets will cause it too.
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By justent_88
    • By Mhatayas
    • By Mhatayas
    • By BruceG
