Ozark 250 Carb Question
By hurnyak
What is the best way to remove the carb on a 2000 quadmaster 500? Does the gas tank need to come off first?
By dkgg5755
By Louznmemind
By ResQ91
Hi Guys!
Or ??
Dave
By bwillaub
My carb is kaput. Cannot be rebuilt. Anyone know of an aftermarket carb that will work or a source for used carbs for this model and year? Any info appreciated.
Thanks ahead of time.
