1993 Suzuki King Quad 300 CDI Needed
By rjsummer
By Gtc4d
Thanks.
Todd
By digrig
Hey everyone,
By shorty
I removed a winch, mount brackets, relay box from my kawhockey ATV.. also a sturdy steel tube holder for a gas can.. CHEAP to someone who wants them
By Ant-Knee
I recently picked up a '97 Prairie 400 4x4 that didn't run. I didn't get much information from the previous owner except that it was running a couple of weeks ago, then started losing power. After that, it just wouldn't do anything... no crank, no start. The electric start didn't do anything and the pull start seemed locked up. When I got it, it had no fluids whatsoever—no oil, no coolant, nothing. I figured the engine was seized. I took the pull start recoil off and tried turning it with a wrench but it didn't move. I took out the spark plug and put some lubricant in the spark plug hole. After a while, I was able to get it moving and it turns now but isn't super easy to turn. I put oil and coolant hoping it would fire up but still nothing. I took out the starter and tested it and it worked perfectly. I tested the starter solenoid and it clicked so I assumed it is working. The battery is good and holding a charge. I also put in a new spark plug as the old one was somewhat corroded but didn't look that bad. After I tested the starter, I put it back in and ran some power directly to the starter. It started cranking the first time I gave it power but didn't do anything after that one time.
Any ideas of what I should do next would be greatly appreciated. Always wanted a quad so I really want to make this work but not sure if it is do=able.
