  • Ajmboy changed the title to 1985 Suzuki LT50 No Spark
Thanks but I have 2 new aftermarket coils that don’t work. I was thinking maybe this Lt50 needs a specifically wound coil for it 🤔Excellent spark from the stator wire to ground, but that’s it . Thanks again
a 2 wire coil is pretty much a 2 wire coil.  I'd look at the run/stop/run switch, make sure the coil is grounding on a clean surface, etc.  Likely to be an electrical gremlin if more than 1 coil won't spark.
    • By jay41198
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
