2007 Predator 50 Air Screw Adjustment
- [[Template core/front/widgets/relatedContent is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
Similar Topics
By chimmike
Picked up a 98 Quadrunner 500 for a song. It's in rough shape, but funny enough it turned over and fired on starter fluid. Fuel lines are rotted to snot and the inlet tubes to the carb are rusty. I have a rebuild kit for the mikuni, but I'm wondering if anyone has used any of those alternatives on Ebay or Amazon that say they fit?
By JacobSlabach
Hey I picked up a pit bike and a foreman for 800 the pit bike was running but the foreman was locked up. Sold the pit bike but when I took the top end off the piston I only found half a piston left. So knowing the rest of the piston was down in the crankcase I knew it had to be pulled and gone thru completely.
to pull the motor I went ahead and pulled the rear end off and unbolted the front diff to pull the drive shafts and pull the motor. Now I have the motor torn down completely and have all the parts of the piston removed. I know the rod and crankshaft is shot (heat discoloration and too much up and down play rod to crankshaft).
***so I’m wondering while I have the motor apart what should I check for? I know this motor died from heat as the oil in the head smelled like popcorn. So what should I check to make sure I fix the issue (overheating I assume) and not just the symptoms (blown up motor lol).
Here’s some pics
By JacobSlabach
Hey just picked up another scrambler 850 was told the tps was bad. This atv has been beet to hell. Wiring has been tinkered with the crankcase has been replaced recently and the motor rebuilt (can see horizontal scores thru spark plug hole where it’s just been honed out and rebuilt)
my guess is it was ragged out till the motor blew a rod and rebuilt but the clown that did it couldn’t get it to run again and sold it. When I bought it it would pulse and smoke black at idle and die with throttle.
New tps installed and it won’t run period. I went to celebrate it and I’m getting 5 volts on 2 of the 3 wires running to the tps. Is this normal and if so how should I celebrate it?
By AKMichael
Hello All,
I have a 1999 Yamaha Big Bear 350 4x4 trying to get fixed up so my grandson can go out in the woods with me.
We have owned it over 10 years. It got harder to start, until it finally would not. Replaced the carb. Right afterwards, it started and ran nicely, but after turning it off, would not restart. Tonight I used starting fluid and ran, then died. Adjusted the idle up a little, used more starting fluid and ran great. It idled about 15 minutes. Turned it off, and restarted. Ran it around the yard about 5 minutes. Turned it off, and would not restart.
Any ideas or suggestions would be greatly appreciated!
Thank you.
By Wiley1
Anybody know what the valve clearance is for intake and exhaust on a 2017 sportsman 570? I did a search but it came up with nothing.
