Start with draining the float bowl on the carb and putting new fuel in the tank. I'm assuming this is the first time starting in a while? If so you've accumulated water in the tank and it found it's way to the carb float bowl. Water is heavier than fuel and will sink to the bottom. This new ethanol fuel sucks moisture out of the air and that's how the water gets in the fuel.
Well I found out what was wrong with my King quad I rebuilt the carburetor and it still had the same problem idle perfect but when gave it gas it had no power I threw in the towel brought it to the mechanic that works on ATVs and bikes. He found the problem it was an electrical problem he had to replace my rectifier ATV runs perfect now.
    • By kevinohio
    • By buriedpast
    • By LMI
