yamaha big bear 350cc what year do i have??
By ranchhelper
VinDecoderz says it's a YFM350 (Moto4 350) trim YFM350ER
Is that a Big Bear? Or a Moto 4? Or are they the same thing?
I've google'd around for information, and was able to find a (czech board in english) that had a Yamaha service manual for the YFM350X series, LIT-11616-YM-37. The 'Warrior' type. I'm trying to get something more accurate. I'm not sure which manual I need. Pictures included in this post.
I'm also looking to get a wiring harness for it.
By semicolon
By NZrider
By jatho
By hardcastle
