yamaha big bear 350cc what year do i have??
- [[Template core/front/widgets/relatedContent is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
Similar Topics
By Leski991
Hello,
I have read many forum topics on this matter but have never found a similar problem. So i bought a cheap ass quad thats got all sorts of parts on it. It's a 1997(if you look the date on frame) Kawasaki KLF(Bayou) 300 EUROPEAN Model (atleast I think, since I'm from Europe), the engine is 1988 if I'm not mistaken and the CDI is 1995.-2006. ( 21119-1447, 6pin ). My problem is that I don't have spark. I would diagnose the issue but connectors from CDI to wiring harness have almost all different colors and I'm not sure if they are connected correctly (pictures below). Pickup coil is putting out around 400 ohms and is pulsing. CDI is being fed 12v by one y/r wire that is coming to connector and with 12v to one gray wire which is coming from ignition switch ( quad actually doesn't have ignition switch so I'm not sure if gray should be supplying power or not). Stator looks good cause when crancking all three yellow wires put out around 5v AC. Neutral light is also on which means the switch should be ok, if it even matters. I know it's not the ignition coil since I get no power nor any kind of pulsing to G/W wire that is coming to it ( and I even put another one on there just to check an it ended with the same result). I'm nowhere near proffesional around this type of stuff so any help would be amazing.
By Wali
i have a 2003 can an outlandee 330 4x4...
it wont move when i shift it into gear (H/L/R).... the secondary clutch spins in neutral, put once engaged into gear, the clutch stops spinning and wont go.
any ideas what to check?
By mpovah
Hi all, new member here.
Picked up a really cheap non-runner last night from a neighbor. He had gotten it from someone else who had rebuilt it a few years ago and it has decorated his garage since.
It is an early-90's (1992 or 93?) Suzuki LT250, but the weird part is the engine is a neon green color. I am now wondering if someone swapped the original motor out of this quad. Does anyone have experience with these that could give me a pointer as to what this could have come out of? I have heard that some Arctic Cat models had the same Suzuki motor - could that be where this came from? It is a 2WD, and has the typical chain drive/RWD system with both front and rear (rear drum) brakes. Very little rust and mostly complete, for the price I paid it isn't bad, but I am not sure how to pinpoint the engine type, and I would like to have that figured out.
Just want to make sure what I am dealing with before ordering parts. I will need a carburetor by the looks of things, and air/oil/fuel filters, plugs, etc.
Thanks in advance for any help, appreciate your experience with these quads.
Matt
By chimmike
Picked up a 98 Quadrunner 500 for a song. It's in rough shape, but funny enough it turned over and fired on starter fluid. Fuel lines are rotted to snot and the inlet tubes to the carb are rusty. I have a rebuild kit for the mikuni, but I'm wondering if anyone has used any of those alternatives on Ebay or Amazon that say they fit?
By Sha35297
Hello, got this bike in to replace the jug and piston. Made the swap, crank looks good, no play in connecting rod. Put it all back together and then heard a rubbing noise in the rear crank case. Ordered a new timing chain and tensioner. Installed them and put it all back together. Fired it up and ran great on the work bench. Took it down and went for a ride and noticed the higher the rpms, the noisier it got. There was a tapping noise on the exhaust side of the valve cover. Removed valve cover. Checked valve clearances, all good. Checked the valve springs, the were a good bit out of tolerance. Installed brand new springs. Same noise. Decided to replace the whole cylinder head with one from a known good bike. Still the same noise. Decided to replace the camshaft with one from a known good bike. Still makes the noise. Replaced lift caps. No change. I’m at a loss on what could be causing this noise. It’s very loud and not normal by any means. Any suggestions would be appreciated. Video doesn’t really pick up the noise good, but it’s there.
IMG_2225.MOV
