Locked up Honda Foreman 400 full rebuild
Similar Topics
By Quad king
I am not sure what is wrong with my King Quad. I had a new carburetor put in 6 months ago, just replaced the fuel pump and added an in-line fuel filter in. I have been trying to fix this quad for a while now and do not know what is wrong with it. It idles fine and runs great as soon as it is fired up, you can Rev it and stay in first gear with 100% power. As soon as I drive 10 feet it looses all power, I mean it is sputtering and doesn't move at all, but when I let off the gas after it sputters it idles fine. I will attach a video of what it is doing.
Snapchat-1290161440.mp4 -
By AgmansGrizzly
Hello everyone,
Im new here, this is my first post and Im trying to figure out how evrything works on this site so I please let me know if Im doing anything wrong.
I have a couple Yamaha's but this post is in regards to my 02 Grizzly 660, I have an electrical draw somewhere that is taking my new battery down rather quickly. I have tried to locate any short by checking each circuit but was not able to locate it that way. Im installing a battery cut off switch which brings me to my first question, dont these switches usually go on the Negative terminal?
My next question is, can anyone tell me if this year and model has any history of electrical shorts that might help me locate the culprit? Any help would be greatly appreciated!
Finally, Im looking forward to being a member of this site and hopefully helping others as well as learning some things myself, so greetings to all!
Best wishes to everyone!
By Sha35297
So, I got this 07' Polaris Outlaw 90 in the shop to rebuild top end and transmission. Replaced all bearings and gears in the transmission. Replaced cylinder and piston with brand new parts. Put the engine back on the frame and fired it up. Started great, but had a taping sound in the lower crank case. pulled the flywheel cover off and found the flywheel was wobbling and hitting the stator. I then replaced the stator and flywheel with brand new parts. Timing is all set on the timing marks now, but when I turn it over it kicks back when it fires and ends up stripping the starter idler gear. I've replaced the starter gear once already and now have to replace it again. Is it possible that the timing marks on the flywheel are off or maybe this flywheel is not for this exact model? Thinking of advancing the timing to try it, but don't want to keep going through idler gears.
By Richard Western
Hi guys,
I am hoping someone might be able to help me out. My Kawasaki 300 4x4 has an issue where it doesn't seem to want to go into neutral and also it will shift into reverse without using the lockout knob.
If anyone can suggest what to look at it would be very much appreciated.
Thanks.
By Michael P
Hi i have bayou 400 when i turn it over i get one little spark and that's it? New cdi ,switch, and a used regulator/retifier,new battery any suggestions would be greatly appreciated
