Can anyone tell me if there is an access hole to the crankshaft on this specific model? The fourwheeler hasnt ran in around 5 years. Last year it was cranked, found water in the air box pulled spark plug cranked again, And sure enough water came flying out of the spark plug hole. Drained the oil and was not any water in the oil. However since then it hasnt been cranked and we never filled it back up with oil. Now the engine is seized up and i was hoping it was just the piston and not the crank. How likely is it the crankshaft is locked up?
I  bet your cylinder is rusted. If there was no water in the oil then you might be ok as far as the bottom end goes. you may want to pull the top end to see what you're up against. Youll also get a good view at the crank at that time
    • By Kawasakibayounospark
    • By carkivey3
    • By leecon
    • By pastorjeep
      Need some feedback here. I picked this machine up with PO saying no spark. I have tried new stator, CDI, and coil. The stator ohms 231 w/r to w/g and .1 red to blue. The coil is .8 primary and 2.53 secondary. I have 12 to the CDI with ign on and the wires from stator to CDI have good continuity. This model only has 12v on or off for ign/kill source. Still no spark?
