no spark, I put a new plug in and still no spark...  I took a look at kill switch-jw if there is support to be bb in between the 2 metal spring loaded pieces?  And other suggestions?  I don’t know what the coil, plug wire, or cdi is supposed to ohm out at?? Repair manual?  Where is cdi located?? And is there supposed to be a green wire coming off of coil?  HELP!!!’
On 8/10/2021 at 7:03 PM, Jakelam said:
I had the bike running perfectly fine, my buddy took it for a little ride. After he got back he hit the kill switch and forgot to turn the key off. We went to grab some food for about an hour. I went to start the wheeler up again and it didn’t start. I obviously switched the kill switch to run. It turns over but won’t go. I Pulled the spark plug out and threw a new one in, been in there since I bought it. Tried starting again and still got no spark. Where would I start troubleshooting this issue?
Also, the fuel pump is not engaging...where do I start?
I pulled the chassis relay and get a clicking noise...also when that relay is in—you can feel it clicking—do you think it’s a bad relay?  Or could it be wiring somewhere?
Feel pumps are common issue with these year machines. Check for power to the pump if it's ther remove cap and listen when key is turned on should hear pump prime if you hear gas drain back into tank pump is definitely bad
  • 6 months later...
    • By TomJulio
      My 1992 TRX00 recently stopped firing.  I understand this is a common problem. I have ordered an aftermarket CDI unit.    TJ
    • Guest
      By Guest
    • By RGS
    • By ncutts
      hey all looking for some guidance on my KQ just replaced stator, and regulator on the quad and after putting all the plastics back together and finishing the snorkel kit she has no spark when i check voltage on the power wire going into ignition coil im getting about 12v and if i crank it im not getting my "peak voltage" (80v) any help would be greatly appreciated
      thanks , Nick
    • By Sketchy
      I've finally been able to get the plugs to spark by replacing the coils, regulator,  and cdi.  When checking the plugs for spark I noticed that they would spark for only a second or two and then no spark.   I release the start button and try again with the same results.  Shouldn't the plugs keep sparking with the start button pushed?  Thanks in advance.
