    • By BillR94
      Thank you for your time
      Bill
    • By wjmedic
      Recently rebuilt front end on this Polaris 400. New axles, bearings, seals, control arm bushings, Hilliard clutch thoroughly cleaned and inspected with no damage noted.
      Everything put back to together. Placed bike on jack stands all four wheels off the ground, started in 2 WD switched to AWD both front tires spinning, when AWD turned
      off right front wheel will not disengage from AWD. Checked voltage at connectors both left and right connectors have no voltage with AWD switch off, and both have 12.4V
      when AWD switch is turned on. Repeated turning switch on and off several times with no change in condition. I am thinking this must be something mechanical with the
      Hilliard clutch on the right hub ie. weak spring or stuck rollers on the Hilliard clutch assembly (Is this a logical thought?) any ideas on trouble shooting this before I disassemble the
      right front hub again
    • By sunn
      Has anyone had experience with the installation of the Optional RH Side Panel Close Off Kit as shown as p/n 2207445 which is supposed to help control the heat on the right side on my legs?  Right now that panel is wide open with excess heat on my leg.
    • By gohndd
      Hey guys, I have a 1999 king quad. The right front brake locks up when I squeeze the lever. I can loosen bleed screw, fluid will come out and it unlocks. I'm thinking maybe wheel cylinder. Any suggestions?
      When it comes to all-terrain vehicles (ATVs), having the right tires can make a world of difference in performance and safety. ATV tires are designed to handle various terrains and conditions, and selecting the appropriate ones for your specific needs is crucial. In this article, we will provide you with a comprehensive guide on how to choose the right ATV tires, considering factors such as terrain, tire type, size, and tread pattern.
      Determine your terrain: The first step in selecting the right ATV tires is to consider the type of terrain you will be riding on most frequently. Different terrains require different tire designs to optimize performance. Here are some common terrain types and the corresponding tire suggestions: Mud: Opt for tires with aggressive tread patterns, wider spacing between lugs, and self-cleaning capabilities to provide maximum traction in muddy conditions. Sand: Look for paddle or scoop-shaped tires with a large surface area to provide floatation and prevent sinking in soft sand. Rocks: Choose tires with reinforced sidewalls and durable construction to resist punctures and withstand rough terrains. Trail/General Purpose: For mixed terrains, all-purpose tires with a balanced tread pattern that offer good traction and durability are ideal. Consider tire type: ATV tires come in different types to suit specific riding preferences and conditions. The main types include: All-Terrain (AT) Tires: These provide a good balance between on-road and off-road performance, making them versatile for various terrains. Mud Tires: Designed with aggressive treads and deep lugs, they excel in muddy and slippery conditions, offering excellent traction. Sand Tires: Featuring a paddle or scoop design, these tires provide optimal traction and floatation in sandy environments. Racing Tires: Specifically engineered for high-performance ATV racing, these tires offer enhanced grip and maneuverability on tracks and trails. Determine the tire size: The size of your ATV tires greatly impacts its performance. It is essential to consult your ATV's manual or manufacturer specifications to determine the correct tire size. The size is usually indicated by a combination of numbers such as tire width, aspect ratio, and rim diameter (e.g., 25x8-12). Ensure that the selected tire size matches your ATV's recommended specifications to avoid clearance issues and maintain optimal handling.
      Evaluate tread pattern: The tread pattern of ATV tires plays a vital role in traction, stability, and overall performance. Consider the following tread patterns based on your riding requirements:
      Aggressive Tread: Suitable for challenging terrains like mud, rocks, and deep trails, these tires feature large, deep lugs for increased traction. All-Purpose Tread: Ideal for general riding and mixed terrains, these tires have a more balanced tread pattern with moderate lugs for versatility. Knobby Tread: Combining elements of aggressive and all-purpose treads, knobby tires provide a good compromise for various terrains, offering decent traction without sacrificing ride comfort. Additional Factors to Consider: Tire Ply Rating: The ply rating indicates the tire's strength and durability. Higher ply ratings generally provide better resistance to punctures and sidewall damage. Tube or Tubeless: Determine whether your ATV requires tube or tubeless tires based on the rim and manufacturer specifications. Brand and Reviews: Research reputable tire brands known for their quality and durability. Read customer reviews and seek recommendations from experienced ATV riders to gauge performance and reliability. Choosing the right ATV tires is crucial for optimal performance, safety, and enjoyment during your off-road adventures. Assessing factors such as terrain, tire type, size, and tread pattern will help you make an informed decision. Remember to
