Getting the plastic off a quad
Go to solution Solved by WantToBe,
I got a quad at the right price... FREE
I have to repair the brakes and engine so I gotta take off the plastic, BUT that's the issue. The handle bars bracket has got me stumped. When I remove the handle bars you can see a 6mm bolt in the bracket so me thinks unscrew that and all should be sweet. I unscrew it a good 25mm/1" and it feels like there is still more to go but the bracket is still rock solid. I would have thought the bracket would show signs of movement.
Anybody can confirm I should keep unscrewing the 6mm bolt? I doubt I should be unscrewing the steering shaft itself just to remove the plastic.
I am a first timer so do not want to stuff anything up
1
2
3
4
5
I remember taking off the bit nut on me push bike many decades ago and ball bearings (from the race) going everywhere on the floor 😝.
Going to work on it again today. Decided to unscrew the 6mm bolt all the way and see what happens. Last resort is the big nut 🤞
That plate's probably on a tapered or splined shaft. I'd wind that six mill bolt out a small amount, perhaps six turns, then either use a puller and pull the plate or lever it up, and give the bolt a sharp tap with a small hammer. Don't bash it too hard or you'll bend the bolt. It's not likely to damage the threads if it is a long bolt as you say..  Allen keys are tough. If you are using a puller, press against the allen key and then tap the end of the puller's bolt..
If it's a splined shaft the plate should move with the puller, but if it's a tapered shaft it will need a tap, either on the end of the allen key, or on the side of the sleeve under that plate.. A sharp tap with a small engineers hammer's better than a hard whack with a bigger hammer.
  • Solution
Took the 6mm bolt out completely, still the steering bracket was rock solid. Loosened off the big nuts and from the underneath that wasn't going to help. Time to get the 'persuading' tools out.
After giving it a WD40 squirt I give the bracket a couple of taps with the hammer, nah no good. Next up was the big screw driver, jammed it in the bracket and with a sideways force give the handle a whack. Jackpot, it come loose. Mission accomplished.
Thanks for the advice guys 😉
10
12
13
14
    • By Dsluder
    • By Jdeaton011989
    • By GatorHunter
      Thank you, and enjoy
      GH
      1985 Scrambler
      1985 Trail Boss
      1986 Scrambler
      1986 Trail Boss
      1987 Trail Boss
      1987 Trail Boss 4X4
      1987 Cyclone
      1988 Trail Boss 2X4
      1988 Trail Boss 4X4
      1988 Trail Boss 250 R/ES
      1989 Trail Boss
      1989 Trail Boss 2X4
      1989 Trail Boss 4X4
      1989 Big Boss 4X6
      1990 Trail Blazer
      1990 Trail Boss 250
      1990 Trail Boss 2X4
      1990 Trail Boss 2X4 350L
      1990 Trail Boss 4X4
      1990 Trail Boss 4X4 350L
      1990 Big Boss 4X6
      1991 Trail Blazer
      1991 Trail Boss 250
      1991 Trail Boss 2X4
      1991 Trail Boss 2X4 350L
      1991 Trail Boss 4X4
      1991 Trail Boss 4X4 350L
      1991 Big Boss 4X6
      1991 Big Boss 6X6
      1992 Trail Blazer
      1992 Trail Boss 250
      1992 Trail Boss 2X4
      1992 Trail Boss 2X4 350L
      1992 Trail Boss 4X4
      1992 Trail Boss 4X4 350L
      1992 Big Boss 4X6
      1992 Big Boss 6X6
      1993 250 2X4
      1993 350 2X4
      1993 250 4X4
      1993 350 4X4
      1993 250 6X6
      1993 350 6X6
      1993 Trail Boss
      1993 Trail Blazer
      1993 Sportsman
      1994 300 2X4
      1994 400 2X4
      1994 300 4X4
      1994 400 4X4
      1994 300 6X6
      1994 400 6X6
      1994 Trail Boss 2W
      1994 Trail Blazer 2W
      1994 Sportsman 4X4
      1994 Sport
      1995 300 2X4
      1995 400 2X4
      1995 300 4X4
      1995 400 6X6
      1995 Trail Boss
      1995 Trail Blazer
      1995 Sportsman 4X4
      1995 Sport
      1995 Xplorer 4X4
      1995 Scrambler
      1995 Magnum 2x4
      1995 Madnum 4X4
      1996 Trail Blazer
      1996 Trail Boss
      1996 Xplorer 300
      1996 Xpress 300
      1996 Xplorer 400
      1996 Xpress 400
      1996 Sport
      1996 Scrambler 4X4
      1996 Sportsman 4X4
      1996 Sportsman 500
      1996 400 6X6
      1996 Magnum 2X4
      1996 Magnum 4X4
      1996 Magnum 6X6
      1997 Trail Blazer
      1997 Trail Boss
      1997 Xplorer 300
      1997 Xpress 300
      1997 Xplorer 400
      1997 Xpress 400
      1997 Xplorer 500
      1997 Sport 400
      1997 Scrambler 4X4
      1997 Scrambler 500
      1997 Sportsman 4X4
      1997 Sportsman 500
      1997 400 6X6
      1997 Magnum 2X4
      1997 Magnum 4X4
      1997 Magnum 6X6
      1998 Trail Blazer
      1998 Trail Boss
      1998 Xplorer 300
      1998 Xpress 300
      1998 Sport 400
      1998 Scrambler 400
      1998 Scrambler 500
      1998 Xplorer 400
      1998 Magnum 2X4
      1998 Magnum 4X4
      1998 Sportsman 500
      1998 Big Boss 500 6X6
      1996 Sportsman 400
      1996 Sportsman 500
      1996 Xplorer 500 4X4
      1997 Sportsman 400
      1997 Sportsman 500
      1997 Xplorer 500 4X4
      1998 Sportsman 400
      1998 Sportsman 500
      1998 Xplorer 500 4X4
      1999 Sportsman 400
      1999 Sportsman 500
      1999 Xplorer 500 4X4
      2000 Sportsman 400
      2000 Sportsman 500
      2000 Xplorer 500 4X4
      2001 Sportsman 400
      2001 Sportsman 500
      2001 Xplorer 500 4X4
      2002 Sportsman 400
      2002 Sportsman 500
      2002 Xplorer 500 4X4
      2003 Sportsman 400
      2003 Sportsman 500
      2003 Xplorer 500 4X4
      A01CH50AD
      A01CH50AA
      A01CH50AB
      A01CH50AE
      A01CH50AK
      A01CH50AF
      A01CH50AJ
      A01CH50EB
      A02CL50AA
      A02CL50DA
      A02CH50AA
      A02CH50AB
      A02CH50AE
      A02CH50AK
      A02CH50AC
      A02CH50AD
      A02CH50AJ
      A02CH50AL
      A02CH50AM
      A02CH50AN
      A02CH50FA
      A02CH50AAEB
      A02CH68AA
      A02CH68AB
      A02CH68AC
      A02CH68CA
      A02CH68CB
      A03CL50AA
      A03CH42AA
      A03CH42AB
      A03CH42AC
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03GJ50AA
      A03GJ50AB
      A04CL50AA
      A04CH42AA
      A04CH42AE
      A04CH42AG
      A04CH42AQ
      A04CH42AT
      A04CH42AV
      A04CH42AS
      A04CH42AR
      A04CH50AA
      A04CH50AC
      A04CH50AE
      A04CH50AG
      A04CH50AO
      A04CH50AQ
      A04CH50AR
      A04CH50AS
      A04CH50AT
      A04CH50AV
      A04CH50AW
      A04CH59AF
      A04CH59AH
      A04CH59AJ
      A04CH59AT
      A04CH59AV
      A04CH59AK
      A04CH59AL
      A04CH59AN
      A04CH59AW
      A04CH68AC
      A04CH68AF
      A04CH68AH
      A04CH68AJ
      A04CH68AT
      A04CH68AV
      A04CH68AK
      A04CH68AL
      A04CH68AN
      A04CH68AO
      A04CH68MB
      2004 Ranger 2X4 Parts Manual
      A04RB42AA
      2004 Ranger 4X4 Parts Manual
      A04RD50AA
      2004 Ranger 6X6 Parts Manual
      A04RF50AA
      A05CL50AA
      A05MH42AB
      A05MH42AG
      A05MH42AH
      A05MH50AB
      A05MH50AC
      A05MH50AG
      A05MH50AH
      A05MH50FB
      A05MH59AK
      A05MH59AN
      A05MH68AK
      A05MH68AN
      A05MH68AC
      A05MH68AS
      A05MH68AU
      A05MH68AW
      A05MH76AC
      A05MH76AU
      A05MH76AW
      A05MH68AP
      A07MH68MA
      R07RF68AD
      R07RF68AF
      R08RF68AD
      R08RF68AF
      2009 Outlaw 90 service manual
      Other Stuff
      Download Manuals HERE
      Some ATV manuals available in the downloads section at https://www.quadcrazy.com/files/
      Find them on on:
    • By gordonmacritchie
      all fuses are fine
    • By quadnut20
      What does everybody carry to fix tires on trails ? Looking for suggestions on Kits to buy !!
