Similar Topics
By mga
I just brought home a used 2005 Yamaha Big Bear 400 4x4. It needs front wheel bearings, and a new choke cable. I think i can handle those two items. However, when i went to look at it, it ran good, shifted good, brakes all workds great, but at home when i started it, it would idle nice, but when i gave it gas it seemed like it was flooding out and would die. If i just gave it a little throttle it built up RPMs but any more throttle it began dying out again.
any suggestions why it's doing that?
I'm looking for a service manual, but forum rules say i have to make 10 posts..lol
oops...i just realized i posted in the wrong section of the forum!!
By Am2007
Hi everyone,
owner manual
service manual
engine manual
By Gwbarm
Finally getting around to the Yamaha Big Bear that followed me home in August. It is a mess. I got it off of marketplace, the add stated " runs like nothing is wrong the only thing that's wrong is it needs a new wiring harness". So iv been looking for a new wiring harness although it came with a wiring harness that was out of the bike, so I assumed he had ripped it out. All the plastics were off and no screws or bolts to reinstall but they were in good shape. The coil, voltage regulator and starter solenoid was missing but came with new one. So I go out expecting to start installing the wiring harness and find out its still in tact with these parts missing. The first thing I found was the engine was stuck and there was no spark plug in it. I noticed when I bought it that the pull starter wouldn't rotate the engine but he assured me the engine wasn't stuck that there was something wrong with the pull starter, I was skeptical but took him at his word. I didn't check it that closely because I was really just buying it for the tires and wheels they were worth twice what I paid for the bike. Im a little new at buying on marketplace and am just angry that someone would lie like that, now I don't know if anything is really wrong with the wiring harness, im probably too trusting I usually trust people until they give me a reason not too. I would have bought it anyway, if I go to the trouble of hooking up my trailer and wench and driving there its coming home with me, long as its a Honda or Yamaha I can fix it. It took PB Blaster about 24 hr and I got the engine freed up, and it has good compression, using ye ole thumb over the hole test, and the pull starter works fine Thats enough of that, now for my real question, before I go to the trouble of chasing the wiring problem down I would like to see if the engine is ok , is there anyway to feed voltage directly into the cdi to make it spark.
By JDAlbert
I have several quads and will soon need to replace tires. I typically like to have a complete set mounted and ready to swap out for different kinds of riding but haven't done that yet. What do you recommend and where have you purchased them?
2020 Polaris Sportsman
2013 John Deere Gator
2010 Polaris
Similar Tagged Content
- 0 replies
- 1,540 views
- 1 reply
- 1,646 views
- 0 replies
- 1,178 views
- 9 replies
- 3,570 views
- 4 replies
- 2,270 views
Gallery Images
