Shifter problem on 93 Quadrunner 250 LT-4WD
Go to solution Solved by kenikas,
I've got a problem with the shift lever returning to the centered position, and it seems the same either upshifting or downshifting. It goes in to all the gears ok, but does seem a bit difficult to get in to gear sometimes, but every shift you have to tap the shifter with your toe either up or down to center it before you can shift in to the next gear. The people we bought it from had only used it to plow their driveway in the winter for several years, and had only used 1st and reverse for a long time. I've tried lubeing the cable ends and the shift lever pivot, but doesn't seem to help. Any ideas?
Thanks Mech, yep the lever on the case moves like it should when the cable's disconnected. I disconnected it from the shift pedal as well and the culprit is definitely the cable. I'll try and flush it out and run a bit of cable lube through it and see if I can get it to move smoothly.
And yeah, if the cable looks ok on the outside(no worn off outer)wash it with water and work it to get dirt out if it doesn't look like it's been oiled. If it has been oiled then wash it in petrol or kero.
Is the shifter rubbing the plow lever or mount?
On my 93 with manual plow I had to bend the shifter away from the plow mount to prevent it sticking against the plow parts.
Probably not an issue with a winch operated plow.
Edited by mellephants
  • 10 months later...
  • Solution
Finally getting around to a follow up on this, unfortunately this machine kinda got back burnered and is still in the corner of the garage due to other carb/ignition troubles. But we did come up with a cure for this shifting issue, this is a nylon lined cable, and the Suzuki replacement is surprisingly NOT CHEAP! So we got a serviceable used cable from powersportsnation, that is much smoother than the original. But it still doesn't always completely center when shifting and we're hoping that when we get it running better and ride it around it will loosen up a bit more. My thoughts are that the internal spring on the shaft is a little weak and that's causing part of it, so we just put a couple of "helper" springs on the foot lever, and that seems to have cured it.
    • By RadRob
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
