Hello everyone!  Just joined up.  As an introduction, I've had a Kawaski Bayou KLF300 2x4 since my Dad bought it new in '86 (nearly as old as I am), done a lot to keep it running through the years, especially with starter motor and carburetor work.
I'm also working on a 1993 Suzuki QuadRunner 300 for a friend.  Seems original carb was MIA so he bought one online, put a 120 main jet in and then asked if I could help - still running bad.  So I'm here asking if anyone has the specs for idle screw turns, float height and valve adjustment specs.  Looking to download the service manual soon from here when I'm able to.  I've cleaned out the carb and reassembled it, it had some assembly errors, and so far got it to start and idle fairly well, bit unstable, and it drives good but tends to stumble when starting out with light throttle, and then when releasing the throttle sometimes it dies.  Think I'm getting close to having it dialed in.  Also have to look at the rear brakes, pedal goes through the floor and no braking at all.  Everything else appears pretty good, even the speedometer works.
Thanks in advance to everyone, cheers!~
Bellarmine
Hi Bender, I got my friend's KingQuad all dialed in, brakes fixed, now starts and runs great, he's happy.  Could you give me some symptoms of your own, and I'll see what I can figure out.  I have found in the past that spark problems are very much on or off like a light switch - it either works or not.  Much more common is fuel problems.  Cheers!~  Bellarmine
Nice quad in the profile pic there Bellarmine.
I agree about the cdi, they rarely give problems.. the unit itself mostly go, or die. The fuel system gives more running problems. The charging is a common cause of bad running though too though.
  • 8 months later...
    • By RadRob
    • By Kawasakibayounospark
    • By neilroy87
