Kodiak yamaha is blowing air out of intake
Clayzimmerman
So i replaced the head gasket on my kodiak yamaha and it is not starting i checked and made sure it had spark and was getting gas and then i noticed that it was blowing air out of the intake. i checked the exhaust and i can hold it shut with my hand but i cant hold the intake shut. Any idea what is going on?? Thanks
You might have bent a valve.. Has it got compression now?
Is it firing at all, trying to start, or nothing happening at all ?
You could try starting it, then take the spark plug out and check whether there is fuel getting on it.. Then attach it to the lead, rest the plug on the engine, and watch for spark while you crank it over.
The carby should still be fine unless you were trying to get it running by adjusting the carby.
If the cam timing was off by very much at all, the valve can be being held open when the piston comes up, then the piston hits the valve and it bends the head of the valve sideways..  Bent valve.  It happens !
Take the sparkplug out and put your finger in/over the hole, kick the engine over and it should blow your finger out with force. If you can hold your finger in there.. you have not got enough compression.
You need to pull the head off again obviously, then you'll need a spring compressor, or a friend that has one you can borrow to get the valves out,  then you need one or possibly two new valves and they need to be "lapped in", which you do using something called grinding paste. You can buy grinding paste in small tubs from an engineering supply shop, and they will also be able to sell you something called a valve sucker.. that's what we call them here in N.Z. anyway.. It's to hold and work the valve when you are doing the lapping in. It would be a good idea to get the manual or have a read up on valve lapping.. it's simple but needs pictures really to show what you are trying to achieve, which is an air tight seal of the valve.
When you've done the lapping in, it's really important to clean and oil the valve seats before you put it back together, they need a hard rub with a damp cloth to get the abrasive compound dust out of the metal seat, and, you need to drop the lapped in valves into place, flip the head upside down and fill the combustion chamber with petrol and make sure that the valves are sealing totally.. If you get the result shown in books they should be right.
Then you need to fit new valve guide seals, lube everything and put the valve springs, with the metal washers that go between the springs and the head(very important, look for them when you are taking the valves out or they can get lost), back on. The valve springs are held by little tapered wedges which can get lost easily, especially as you let the spring compressor off as you are assembling, so make sure they are properly seated, and keep your hand over them as you let the compressor off.
Once the head is reassembled  you are back at where you were when you did the head gasket.. Take care to get the cam timing right, get everything absolutely clean, especially all the sealing surfaces, and you should be right.
Get a manual, they are free to download off here, and have a read about the valve lapping, or google it and have a read up with pictures.
Hey thanks alot for the info. I tore the head off and found that the valves look fine but that when the piston hit the valve it pushed the valve straight up and broke the connecter above the valve. I dont know what its called but is it a hard fix looks like it could be…
It was the exhaust valve connection that was broken so i guess that was what was causing air to back up. The intake valve looks great
You should flip the head over and fill the combustion chamber with petrol and see they don't leak.
The part that broke will be called a rocker arm probably.
How far from the edge of the piston was the valve mark on the head ?
If it's near the edge it can effect the rings.
Was it much of a dent ?
No, find the bolt that holds the shaft they pivot on, take it out, and the pin will pull or push/tap out...  I'd think.. There will be washers and springs.. take note.
It would probably be best to get a set of arms. They are probably made to break and have a thin place on them, look around there for fatigue if you want, but I'd get a set.. They would have all been close to breaking if both valves hit and made similar dents.
Hopefully they did their job and saved anything more major. There are a lot of cars with rockers like it and the precaution seems to work fairly well.
Yeah there is some danger there as Dave suggests. It's also possible that the top ring lands on the piston could be pressed down, clamping the rings.
That's why I asked how far from the edge. Perhaps a picture would be a good idea...
If you are sure the valves aren't leaking, then they didn't get much strain on them, they bend really easily.
Ok so i checked the piston and there is a dent only on the exhaust side. They factory indentions are bigger than i remember them being when i had looked at the piston earlier. That caused me to believe that the valves had deepened the dents. According to the pics online the dent is small.
I checked for cracks and there are none.
  • Similar Topics
    • By Params_sweden
      Hi, I have an EU '94 KLF300 Bayou with ignition issues. I got it last summer and used it for about 20 hours, then one sunny day we used it for about an hour, parked it, and then it didn't want to start again. It has a *really* weak spark, I've only been able to see it once while testing.
      I'm just getting started on this, I'm going to go through all the weak/no spark trouble shootings from the manual. Since I've already invested like 10 hours digesting the manual and forum threads that I possibly can, I thought that it would be nice to create a thread like this in case I come up with a solution that can help someone else.
      So far I've replaced the spark plug, I will replace the spark plug cap with a NGK VD05F (5kOhm resistance). I'm going to check the resistance in the pickup coil, stator coil and ignition coil next. I have tried two CDIs, right now I mounted the original CDI which actually gave the most output to the spark plug out of the two
      A question for you, is it possible to make any assumptions about the CDI by measuring the resistance like in the manual? There's a "resistance table" that you can refer to when measuring between the different connections. I'm asking because I haven't yet seen anyone in the forums that has mentioned that they've measured the CDI resistances and made any conclusions from that.
      I'll attach a photo of my Bayou
      Pär, Sweden
    • By Filthy_Mule777
      I'm currently pulling my hair out over a customers 98  bayou 2x4 KLF300b. I've changed every electrical component on it twice and in a couple instances three times. Still no spark, I am baffled. Initially customer brought it to me complaining of a hard start no start situation and in fact, it wouldn't start. I changed the starter relay, spark plug,  CDI box, and starter circuit relay after which it fired right up ran very well but then started having issues with the neutral switch/light where it wouldn't come on and wouldn't allow it start or even turn over. I found in the wiring harness a loose connection, I got it taken care of and secured and that solved the problem. So now that it would crank up again and run fine I called the customer over to test it out see what he thought as I've never heard it run before and I wanted to get his opinion on how it was running. Customer ride it around a little bit pulled it back on my carport and turned the key off and said it was great, and had never ran better or started so easily, then we set up a time for him to come pick it up the following day and he left. Well where he pulled it on my carport and shut it off was in the middle of the carport so I jumped back on it to park it off to the side,  crank it up no problems put it in reverse went about maybe 18 inches and it stalled and ever since that point it has not had spark or run. I replaced the CDI box again with a better brand, I replaced the ignition coil twice put another starter relay on it and I've also changed out the stater and the pick up coil (pick up coil twice) and I'm just I'm lost I don't know what else to do to it. I've had this customers  four wheeler for four months now whereas he's a patient guy I need to get it out of here so I can move on to something else. I've seen dozens of threads across  different sites for off-road, 4 wheelers, ATVs, UTV's, whatever and they are all experiencing the same sort of issue but they never ever post hear the problem was or  the fix. So I'm hoping somebody here has a little bit of knowledge on this particular issue sent since it seems to be so widespread.  Thanks in advance for any help or suggestions.
    • By Atvguy0901
      Thank for the add on quad crazy. I am new here and need some help with my atv. It’s a older Yamaha Timberwolf 250 that I purchased second hand from an person. I got it home ans started to look into it. He stated it needed a cdi box so I ordered one for it and a battery as well also a key switch cause it did not come with one. I put all the parts on it and when I hit the start button it just clicks and noting else. Thank you any help is appreciated.
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • DIY like a pro! Shop from over 1,000,000 Repair Manuals at eManualOnline.com! As low as $14.99 per manual. Shop now.
    • By twheelerk
      Hello I have a 1981 Honda atc 200 I recently rebuilt starts first, second pull no problem, changes through the gears no problem but the only problem I am having is when I give it gas it pops an sounds like it is choking out. I picked up a carb for it seamed too help but still bogs alil when giving it throttle an loses some power…also I have too run this new carb on half choke, any advice would help thanks
  • Similar Tagged Content
  • Gallery Images
