What is the transmission fluid to be used with this quad?  The manual says the following, but it appears to be NLA and I can't find a clear answer on what to use from my searches.  The manual says the following:
Specified Lubricant:
Polaris Premium Synthetic Gearcase Lubricant
PN 2871477 (Gallon) PN 2871478 (12 oz..)
Got this off a Polaris forum
The specified juice is Polaris Premium Synthetic Gearcase Lubricant PN 2871477 (Gallon) PN 2871478 (12 oz..) Capacity: . . . . At change: Approx. 20 oz.
You could use ATF, Harley high shock synthetic transmission oil, Bel Ray Big Twin transmission lube, (my favorite) Honda two stroke transmission oil or any JASO rated 5w20 through 20w50 multi grade engine oil approved for use in motorcycles that lube the transmission with the same oil as the engine.
Shop Owner and Mechanic with over 50 years experience
I don't like the sound of that advice Dave.. Transmission fluid is nothing like engine or gear oil.. Gear oils and engine oils are two totally different things too..
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
