2005 yamaha 350 won't stay running help please
By LCP92
Guys, I've got a 1999 Honda Foreman 450S. It runs great, but smokes out the exhaust after startup until it warms up. I'm thinking the valve seals are leaking. I was wondering if there is a way to replace them without removing the head or if there's an oil additive that will recondition the rubber seals. Any advice?
By BillR94
Thank you for your time
Bill
By Jason39
I’m having a issue with my choke when its on it runs fine when I cut the choke off the atv cuts off went to take the carburetor off and saw the choke plunger broke at the nut to screw it in could this be my issue? Do I just need to buy a plunger kit and put it on? I took the carburetor off and cleaned both jets anyway just to make sure and it’s still having issues staying on
By frugalsob
Hey all, been a while since my last post and can't find anything exactly like I'm experiencing.
I have a 1996 Polaris Xplorer 300 and have fuel consistently (based on my opinion) drip from the overflow tube attached to the bottom of the carb. When parked and the fuel petcock turned on, it does not leak. However, once its running, it drips almost 1 drop per second. But only at idle. Once rpm's increase it doesn't drip.
I've cleaned the carb, checked the float per service manual, and the rubber needle tip doesn't appear to be worn.
Is this dripping normal? I really dont feel it should be. Or, do I need to replace the needle despite how I feel it looks.
Any help would be appreciated!
Thanks!
By DPDISXR4Ti
Thanks...
