When I turn on key back light on the display works. The display shows shifter positions, temp and engine icon. But the main display is blank.
It will not start fuel pump not working, but that info would come from controll Modular?
Thanks for any ideas
I have checked most connectors, battery is up.from what I-read in the manual it has a diagnosis but the display is blank,I think it shows up there? Checked all the fuses,swapped relays. This thing has more wires, connection ,sensors than the space shuttle.
Got back to the wheeler,after checking all connections, fuses,there was a bad diode,that didn’t help. Then I started checking voltages at the fuses and found the two fuses that are on the starter solenoid had no voltage. The solenoid worked but there must be an internal line to the fuses that opened.
thanks all that responded
    • By HTOverland
    • By realpilot
    • By OldATVowner
