2010 POLARIS Ranger 6x6 800 EFI Repairs
Go to solution Solved by Mech,
Just joined the Forum. I use the 6x6 for work at property several hours from where I live. It has been a really good UTV for what I use it for.  Having to do more & more repairs and parts replacement. Being that I can only work on it when I travel to the farm, I need to diagnose, the order parts to install on a subsequent trip.  Hoping to be able to get advice, tips, lessons learned from QUADCRAZY Members. . I have am trying to learn how to do diagnostics, proper repairs, proper parts replacement, etc. At some point, I would like to purchase another 6x6 and get it in great shape as well. If any of you have a Ranger 4x4 or 6x6 800 EFI, I would be pleased to hear from you. Certainly would like to pick your brain regarding current issues I'm having. Thanks in advance.
My latest issue is with the engine revving wildly all by itself. For now I'm assuming its a bad TPS sensor or connector. Ordering a TPS sensor from Polaris is $250+.     Should I use only the OEM TPS Sensor or is there a good aftermarket sensor that will work just as well for a lot less $$$.               Looking to purchase a Diagnostic Tool. Found a CHECKTECH POLARIS Diagnostic Tool online at OTBPOWERSPORTS. Anyone familiar with the CHECKTECH and have comment or have advice about a different brand?         Thanks again.
  • Solution
I don't have one or know much about any of them in particular, but I know that you can do quite a bit of diagnostics using the service manual and the dashboard display on most of them.
The engine anyway is fairly well supported.. the EPS maybe not so much.
Edited by Mech
  • Similar Topics
    • By Jim Denton
      These chains look way useful for anyone doing ❄️ snow work.
    • By Filthy_Mule777
      I'm currently pulling my hair out over a customers 98  bayou 2x4 KLF300b. I've changed every electrical component on it twice and in a couple instances three times. Still no spark, I am baffled. Initially customer brought it to me complaining of a hard start no start situation and in fact, it wouldn't start. I changed the starter relay, spark plug,  CDI box, and starter circuit relay after which it fired right up ran very well but then started having issues with the neutral switch/light where it wouldn't come on and wouldn't allow it start or even turn over. I found in the wiring harness a loose connection, I got it taken care of and secured and that solved the problem. So now that it would crank up again and run fine I called the customer over to test it out see what he thought as I've never heard it run before and I wanted to get his opinion on how it was running. Customer ride it around a little bit pulled it back on my carport and turned the key off and said it was great, and had never ran better or started so easily, then we set up a time for him to come pick it up the following day and he left. Well where he pulled it on my carport and shut it off was in the middle of the carport so I jumped back on it to park it off to the side,  crank it up no problems put it in reverse went about maybe 18 inches and it stalled and ever since that point it has not had spark or run. I replaced the CDI box again with a better brand, I replaced the ignition coil twice put another starter relay on it and I've also changed out the stater and the pick up coil (pick up coil twice) and I'm just I'm lost I don't know what else to do to it. I've had this customers  four wheeler for four months now whereas he's a patient guy I need to get it out of here so I can move on to something else. I've seen dozens of threads across  different sites for off-road, 4 wheelers, ATVs, UTV's, whatever and they are all experiencing the same sort of issue but they never ever post hear the problem was or  the fix. So I'm hoping somebody here has a little bit of knowledge on this particular issue sent since it seems to be so widespread.  Thanks in advance for any help or suggestions.
    • By alexwv1863
      Can anyone tell me if parts from either a 2000 or 2001 Kodiak 400 will fit a 04 Kodiak 450? I'm specifically needing to replace the fixed and sliding sheaves, and primary clutch and secondary clutch. I could be getting a couple names mixed up but that's the main parts currently. I'm looking on eBay and they look similar, if not identical, to what I'm needing to replace. I just don't want to buy parts and they be too small. Thanks.
    • By Hoyt1500
      I'm rebuilding a 2004 Suzuki LT80 and am wondering where everyone is buying parts for their carbs, clutch, and transmission. Has anyone had success with Amazon parts or should I stick to OEM parts that can be found on partzilla or suzukipartshouse.com. I found one old thread where people talked about only buying OEM for top end but other locations should work.
    • DIY like a pro! Shop from over 1,000,000 Repair Manuals at eManualOnline.com! As low as $14.99 per manual. Shop now.
  • Gallery Images
