Did my timing chain come off?
p5200
A youtube video, showed a guy who had 2 atvs just like mine that had the chain off the bottom gear. He was replacing the chain on one and pointed at the other one and said it had the same problem. He never said if he had anything broken but, it must be a common problem for these particular atvs.
Check the ratcheting mechanism on the tensioner really carefully..  If a motor backfires or bounces backwards as it's coming to a stop, the tension comes on the wrong side of the chain and can subject the tensioner to pressures it wasn't designed to take..  A defective ratchet can fail under those conditions..
Yeah, we can inspect the chain for wear, and the slippers, and be pretty certain whether they are ok or not. The tensioner is the tricky bit. And that backfiring throwing the chain or timing belt is well known. Some motors they warn you against rotating backwards because the belt can jump.
Things were going pretty good untill I screwed up. The main drive gear shaft had left hand threads but, I had to try taking it off with my impact the wrong direction. I know, the nut is ruined I don't know for sure about the drive shaft threads but, I probably, ruined it too. 😞 There are some plastic pieces also. I'll post a couple photos.   Photo of shaft threads may be ruined, and photo of some of the black plastic pieces.
I had crank threads buggered up on a Yamaha DT 400 I was building, I measured with mm ruler, of course your tap and die set never has the one you need, but was handy measuring the thread pitch. I then ordered the one I needed to straighten the threads up, it worked, of course machine shop would be better but I didn't want to haul the bike there to get it done. If you have calipers you could definitely measure it with that, I did that also, but mine were not really expensive ones so I double checked with mm ruler. Will your nut start back on there at all. You might get away with just buying a new nut, get two, get it started and let it straighten out the threads.
I'd get a thread file first and try cleaning that thread up. The thread file will tell you what the pitch is, Hopefully the threads will come right and a new genuine nut will do. if you need to find a nut,you will have to make an educated guess what size it is by measuring the diameter. It will be a metric diameter and although most metric threads are whole mm steps you can get special threads in half mill, so measure carefully.
You won't get a left hand thread in any common tap and die set, but they can be bought quite easily individually if you really need one. If the tread file won't clean up the threads though then neither will a die nut.
And yeah, zap guns are hard on threads always and shouldn't be used for routine undoing stuff. They spin too fast and promote galling even in good threads.
The nut that came off doesn't hardly have any threads left I wondered if trying a new nut on there would straighten things up. If I can figure out what nut I need, I'll order a couple and give it a try. If I can find my wire brush I can clean the threads a little better where I can see them better. This Diabetes and Glaucoma has really done a number on my eyes.
Oh ok, sorry to hear about the eyes. Mine aren't what they used to be either..
Get a thread file for metric threads, they are cheap and come with eight different pitches on each one. You hold them near the thread and look(squint) to figure which one fits best..haha. Then you just gently rub them up and down over the old threads at the right angle for left hand threads.. turning the shaft or rocking the file as you go..
SCA_282093_hi-res.jpg?sw=1000&sh=1000&sm
Edited by Mech
And seriously, those rattle guns are not good for working on things..  Nuts and bolts need to be turned slowly, especially while they are still tight, but even after they are loosened off, if you try to wind a nut down long threads too fast, even by hand, they will get tight..
I hope, I'll be able to get the nut to thread on. I'm thinking since the nut is so smooth on the inside that a lot of what I'm seeing on the shaft is fill in from the nut threads. I guess I should look for a black plastic tensioner piece at least, since I'm pretty sure that's what broke. It's the one that's bolted in I wonder, if I took the bolt out if I could pull it out and get a better look at it? Thanks
    • By lester
      I picked up a 2000 Big Bear 400 4X4 that was sitting around that I know nothing about. It will not start. I do have a red light when in reverse. When I take it out of reverse, I do not get a green neutral light, and when I push the start button the red oil light comes on but there are no noises, nothing else happens. How do I test the neutral switch and/or bypass it to see if I can get it to at least crank? And does anyone have other suggestions for me to try?
    • By Flash_fella
    • By Werewolf
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
