1987 Quadrunner 300 Carburetor
By cavry
Thanks for any help
Cavry
By hardcastle
By Gwbarm
I Ran across this video today comparing an aftermarket to OEM Carb on Suzuki Vinson, thought it might generate some interest, it is quite long but informative.
By Uglyside38
I have a 1988 Quadrunner 250 2wd. My brother in law sold it to my son for $20...had been sitting outside for several years. Got it home and had it running in about 30 mins. Ran it a bit and then went to looking at the carb as it was having trouble idling. Was getting it pretty close, then started losing spark...Also, it wouldn't start up every time...only about 1 in 5 tries. Anyway...now, it has what I can only describe as "intermittent" spark. I can get 1 light spark right when the start button is pressed and sometimes one when it's released...but none while cranking. 🤷♂️
By Louznmemind
Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues... It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
