  • Ajmboy changed the title to 1997 Arctic cat 300 No Spark
You have replaced the major parts, I would check to make sure you are getting voltage where it needs to be 12 v to cdi, ground is good at cdi . Check your pick up coil resistance. Did it just quit or what happened.
    • By Mreoiwerk
      New member here. Hope will enjoy my staying here.
    • By tepin
      Im new to this what are some things i should know?
    • By 88classic
      I have (2) sets of brand new plastics available for Honda Rancher 420 2014-2023. These are genuine genuine OEM Honda plastics. One set is white and the other set is green. The boxes these are in are too big to ship.(Unless you want to pay for it. If so, lookup your own shipping rates from 17325 and box size is 58"x35"x18").  $400
    • By Shorty51
