Suzuki Eiger 400 2004 Rear Wheels Locked (Next Restoration Project)
Go to solution
Solved by Gwbarm,
By docdoug72
Has anyone had a suzuki 230 quad lock the engine up? Its a well maintained bike, it locked up when my son was riding it. Pulled the plug, it has connected with the piston. I'm thinking the con rod let go. I don't have a service manual. Does the engine need to come out to check further?
By Suzukiquad
By RadRob
By Gwbarm
By neilroy87
I have a 1990 Bayou 220 that runs pretty well for it's age--needs a new muffler, but sounds tough. Have had to start with a pull cord since I got it, and recently started troubleshooting the start button. Finding a lot of information on this issue in the forum, but haven't been able to chase it down yet. Got a new battery, new starter solenoid, and going to replace the starter relay this week, but not convinced that's going to do the trick, since I can't get the neutral light on when turning the key on. I can start it by jumping the solenoid, but the 2 black wires to the relay do not activate the starter. Bad ground or a short somewhere? Is there a good way to just test the ground?
