Suzuki Eiger 400 2004 Rear Wheels Locked (Next Restoration Project)
Just about got it read to pull the side cover off,and as I was undoing the last bolt I heard something inside the cover it actually sounded like metal reconforming after you take stress off it, and as I started looking closer it looked like the cover had been hammered on and not with a rubber mallet
IMG_3902.thumb.jpeg.e96a202772af81945104c4202c6690d0.jpeg.
It actually looked like it had been hammered on with a claw hammer, it will be interesting to see what I find in there, I was beginning to loose light and really need to see this in the daytime.
Worked all morning trying to get the case off, went through the manual to see if there is any bolts I forgot, and there wasn't, while looking for forgotten bolts I found a more prominent crack. Still not sure whats holding the case on, I have gotten rough with it and still not coming off, got the top separated  about half inch but bottom is not budging. Just for the record, im not having fun, heat index here yesterday was 108F.
Finally got it off it was just stuck probably to the bearing like you said, I ended up getting 2 pry bars on each side of the case and pulling alternately and then at the same time and it finally popped. I don't like being that rough with the gasket surface, no choice here, I even tried a slide hammer with bolt screwed into the pull rope mounting holes and was afraid I was going to strip it out, I was pulling hard. This is exactly how it came out, im surprised it ran at all, magnets everywhere. Another green gasket tell tale sign somebody's been messing around.
One of the cleanest engines I have taken apart in a while. Notice there are only 2 magnets left on the flywheel and they are loose. Everything else looks good, still messing with it , I just came in to cool for a few minutes, heat index here is 105 today a little better than the 108 yesterday. Further update later.
Yeah nice and clean. See the smaller bearing has pulled out of the case a bit.
That outer gear is on backwards though ! That would be why the case didn't go back on right ?
And the magnets can't have been locking up the engine, or if they did lock up the crank, the centrifugal clutch should have let the gearbox turn in one direction at least..
If you pull the selector fork and those gears off there now, the bottom shaft should be able to turn with the drive shaft.
Ah no..  I see now. That outer gear that was backwards was jammed up against the cover, and couldn't turn, and so nor could the gear below it..
So now you need to figure out why they took it apart to start with..  I bet it wasn't because of a seized driveshaft.. that's the result of their looking for some other problem.
  • Solution
I can get the driveshaft to turn now both front and rear.
I did notice the gear on backwards, jacking it up helped because I didn't have one gear fall out of place, but I did have to drain the oil, guess I didn't jack it high enough, did not notice the bearing, thanks for spotting that, although I am going to try to locate another cover for it this one is bady cracked, I know I can fix it with JB weld but while in in here im just going to replace it, .Get a new rotor turn the gear around and try to figure out what happened to cause him to open the case, also check the neutral switch, it wasn't working, and its inside there too.
It doesnt look damaged.
Yeah that gear just free-wheels around till it's engaged by that sliding dog next to it. It should slide off.. Perhaps see if it turns on the shaft first. That double gear on a hub next to it should pull off too as far as I can tell looking at the book.
The shafts they're on(both shafts and both gears sets) are gearbox shafts and turns. The shaft turning while the gear is jammed up against the case like that might have damaged it in where we can't see yet. It wasn't designed to have thrust loads. It has a couple of end float washers, one on each side of that gear supposedly. Try to turn it and work it off.. probably a burr on the inner side of the gear I would guess.
Thanks for the reply Mech, im feeling kind of stupid right now trying to get this thing off, but I don't know how he put it on, I got an inspection mirror to look behind the gear and there is something there it doesnt look like a snap ring  like the other gear has, looks more like a washer solid all the way around. I was just about to get a puller and pull it off the shaft and thought I better double check, don't want to break  anything.
So I looked up the diagram to see how it s supposed to be together gear number 4 is the backward gear it does not have a lock ring like the gear in front of it and that snap ring is in place, diagram does show a washer between #4 and #5 which is what I must be seeing behind the gear, so I see nothing that is locking it on. It will not budge or hasn't budged yet, I should say. Just wanted a second opinion here, you think I should go ahead and pull it off with a puller. Not sure why but all the videos I have looked at showing this gear it just slides right off, I thought maybe there was a little different taper in the gear itself from front to back, and putting it on backwards may have caused it to stick.
Yeah that's the same picture I'm looking at.. The gear should just slide off with your fingers.
I'm guessing, since you say it (gear 4), turns on it's shaft, that it must be damaged in behind there, perhaps the shaft is made with a tiny groove where the smooth shaft meets the splines, and perhaps the end thrust and rotation, has turned the edge of the gear very slightly so they catch in that groove. If that's the case, and you have the other gear out of the way so you can turn that 4 gear, I'd expect that if you rotate it it will feel free, till you start pulling and turning, at which point you will feel the burr start to grab or drag and things will get tight..
This is all assuming they did run the engine with that case on there..  Or perhaps just their pounding it with a hammer has turned a burr in there..  The case was probably going on crookedly, as it came off, causing things to jamb up.. They must have been tightening the screws and hammering mighty hard to pull the cover over the dogs on that gear,, they will be close to eight mills(3/8) high won't they ?
Better Photo of the shaft from the service manual, gear just must be jammed on there. Just saw your most recent post, I thought the two gears went on to the cogged area and the smooth surface went into the bearing, and the change fork went on the bushing with the oil hole, but the gear does appear to have a bushing in it.
The gear 4 runs right on the end of the shaft almost, and in the drawing it shows an oil hole to it. Then there's a shim and a bearing.
That bush that's splined to the same shaft, part 8 in that manual photo, that has the other gear running on it. Both those two gears are free wheeling unless the sliding, and splined to the shaft dog, is slid along into mesh with one or the other of them.
Oh and look..  in that manual photo.. the shaft does have a groove between the machined round and the splines..  Bingo.. That's where the bush is caught Gw..
It will just be the soft bush damaged.. wind and pull it.. it'll come. Then use a scraper to touch it up.
They likely started out trying to get the switch fixed..  I doubt the magnets were the problem, they got knocked off by them hammering, and perhaps really fell out when you dragged it off.
Magnets are a problem everyone has with this machine the replacement flywheel has internal magnets, I don’t think as you said that was the initial problem, it possible they went into replace the neutral switch gears fell off everywhere and didn’t get it back together right. When I get it all back together I will check the shifting before I put the cover back on to make sure everything is moving and shifting right. So far I don’t see any major problems, haven’t got to it today very hot heat index is supposed to be 110 today
Well finally got enough nerve to get out in the the heat and get it off, heat index got up to 114, but I had to know.
Gear pulled of fairly easily but left the bushing behind
Bushing came off but it wasn't really happy about it, it had a crack in it also I didn't do that it was already there. Washer had wedged itself down in the grove, but it came out, more difficult than the bushing.
Shaft has some damage not sure howits going to affect anything, may have to replace it.
Gear and shaft both got extremely hot not sure if that's from actually using it, or just running the engine, it did run when I got it but I didn't run it very long, previous owner may have. This can get into a fairly expensive fix, flywheel, stator is ok, sometimes that gets toasted as well, shaft, gear and case. Everything else seems OK. It could have been worse.
Ouch !
Well.. If that was my bike, or, under the circumstances, even a customer's with their agreement, which they'd all give knowing I'm a responsible(and competent) guy, I'd clean all that up and put it together with new washers and possibly a bush..  possibly. That bush was probably made with the split. If it's worn get a new bush from the engineering supply shop. Then I'd try the bike out for a bit before ripping it apart again and checking how things were looking and what I'd decided the bike needed in the way of other work.
It's a small investment in gasket and shim etc and only a bit of time..
That heat was caused by the end thrust, and should not in theory have worn the shaft's bearing surface. The heat on the gear shouldn't be any problem as long as the new bush fits nice. The heat on the shaft..  Hard to say. You could try scratching the shaft a little with a file on a place where it hasn't got hot. That will show whether it was a heat treated(hardened) surface. If it's fairly markable on an unheated part then it was soft to start. If the test suggests it was case hardened, then you need to decide how soft it is now..
Thanks Mech, those are my thoughts also, clean it up, I was surprised to see the ridge on the end of the corrugated area caused by the washer, I would have thought the shaft metal would have been harder and obliterated the washer. I am thinking of filing that down even with the rest of the shaft, republish the smooth surface that the bushing rides on and trying with the gear on the right way and see how it works. Im going to see if I can find a bushing to fit tomorrow, if not I have found another gear on eBay reasonable with bushing in tact that should work. I think I will even try the original case for now and see if everything works. Im wondering if the bearing that was raised up in the case may have happened when I was trying to get the case off, I did have to get rough with it to get it off.
Yeah that bearing would have got pulled up out of the side case by the shafts being cocked over in the bearings..  and the tapping and wriggling.
And yeah..  I was wondering if perhaps that shaft isn't slightly soft at the end there where the bush runs..  On purpose. Check it with a file out on the end where the bearing sits.
Yeah I'd file or oilstone all the burrs off, get new washers and check/calculate the end clearances using a straight edge and vernier calipers.
The bush, engineering supply shops have stock bushes, in various materials. You will probably need a brass bush, unless they have some fancy new suggestion, like teflon(not teflon.. it's too soft), but try not to get sold sintered bronze, which is porous and soft and isn't really suitable. Sintered bronze is what lots of old starter and generators used to use, the bushes are obviously porous.. Brass is shiny and not porous. Sintered bronze would do at a pinch, but I'd want to take it out when I had a recheck in there after a few miles. Anyway.. They come in standard metric and imperial internal and outer diameters, and various lengths. If you are lucky you will find one that has both the inside and outer diameters right and only have to cut it shorter perhaps. If not, choose one with the right outer diameter and cut it to length, press it in and then ream, machine or hone it to a nice fine clearance on the shaft.
Thanks I went several places today , no luck, all of the bushings are thicker and not the right diameter, and brass, suzuki doesnt even list it as a replacement part. I will look im sure there are some industrial supplies that may have one. It would be less trouble to just order the used gear on eBay for 12.00.
  • Similar Topics
    • By Jhb12686
      Hello I appreciate the welcome into the group. I am beyond frustrated with this desperate search for parts. I have a 2013 XY power sports UTV 300. I had a catastrophic failure in my rear differential which resulted in the destruction of almost everything inside. I have located everything I need to completely redo the rear end. But I cannot find a short side axle shaft with six splines etc. it's an offset differential and one shaft is longer than the other and I need the short one. The tip of it broke off (pic). Any help in getting another shaft for this thing would be GREATLY appreciated. Thanks guys
    • By 86ccord
      Starting this build thread to keep up with everything on my build and hope to motivate someone!
      I picked up this 2008 Yamaha Big Bear 250 2 weeks ago. A guy that I hunt with parked it at the hunt club for a year or so before I asked him if he wanted to sell. He said " fill my feeder and throw some batteries in my cameras, and you can have it". Sounds like a deal to me!
      I have attached some pictures of how it sat under a tarp in the woods and when I got it home and cleaned up a little.
    • By That229Yamaha
      Hey boys, so a little update with my Yamaha, I now have the CDI box that came in and it’s getting really good spark, but when I go to turn it over, I hear a clanking noise that sounds like something is loose, so I took the stator cover off and my flywheel came off the crank and was magnetized on the stator, nothing serious but like it was unbolted. Is there a way I can keep it from coming off when I turn the motor over? I heard you gotta torque it down with an impact but idk if it’ll work for sure and I’m trying to get this bike back on the road/trails, but at the same time, I’m at the end of my rope with it because it’s getting aggy, but if anyone knows how I can make the flywheel stay on, lmk because some help would be gladly appreciated.
    • Get More For Your Device
      I bought this Eiger about a year ago it has been my runner while i worked on my other projects, except today it wouldnt crank, i suspect it is the  petcock not letting fuel through. When i bought it it had a multitude of problems, but i just ignored those and rode it any way, put it on the back burner while i worked on my other projects with more serious problems, like stuck engine ,wiring harness ripped out, and wheels locked up. Got those all sorted out and since it wouldnt crank today decided it was time to refine this one. When i got it it had a bad Non OEM carb replaced it with a cheap aftermarket until i could find a descent priced OEM to rebuild, and have been riding it ever since. It also had a bad petcock, would only run on prime, neutral light didnt work, no brakes, which are a luxury anyway, but as im getting older luxurys are nice to have, so i guess i will fix those. I paid a little more for this one, $800 but he wanted $1500, because it ran and moved and most things seemed to work, and it didnt smoke, even with the bad carb. Generally 500 is my limit for a non runner, since this one ran i upped my limit a little. So i got it out of the shed before the mice got in it for the winter and started going over it today.
      I would never buy a new camouflaged one because of what you see here, and it almost stopped me from buying this one, but it is what it is, not much i can do for that now, they did look nice when new, i am toying with the idea of replacing the plastics while i can still get them, but am not there yet, expensive.
      I think the snorkel has got to go its not hooked up anyway. Looks like a perfect mouse house.
  • Similar Tagged Content
  • Gallery Images
