Suzuki Eiger 400 2004 Rear Wheels Locked (Next Restoration Project)
Go to solution
Solved by Gwbarm,
Similar Topics
By Gwbarm
By Jhb12686
Hello I appreciate the welcome into the group. I am beyond frustrated with this desperate search for parts. I have a 2013 XY power sports UTV 300. I had a catastrophic failure in my rear differential which resulted in the destruction of almost everything inside. I have located everything I need to completely redo the rear end. But I cannot find a short side axle shaft with six splines etc. it's an offset differential and one shaft is longer than the other and I need the short one. The tip of it broke off (pic). Any help in getting another shaft for this thing would be GREATLY appreciated. Thanks guys
By 86ccord
Starting this build thread to keep up with everything on my build and hope to motivate someone!
I picked up this 2008 Yamaha Big Bear 250 2 weeks ago. A guy that I hunt with parked it at the hunt club for a year or so before I asked him if he wanted to sell. He said " fill my feeder and throw some batteries in my cameras, and you can have it". Sounds like a deal to me!
I have attached some pictures of how it sat under a tarp in the woods and when I got it home and cleaned up a little.
By That229Yamaha
Hey boys, so a little update with my Yamaha, I now have the CDI box that came in and it’s getting really good spark, but when I go to turn it over, I hear a clanking noise that sounds like something is loose, so I took the stator cover off and my flywheel came off the crank and was magnetized on the stator, nothing serious but like it was unbolted. Is there a way I can keep it from coming off when I turn the motor over? I heard you gotta torque it down with an impact but idk if it’ll work for sure and I’m trying to get this bike back on the road/trails, but at the same time, I’m at the end of my rope with it because it’s getting aggy, but if anyone knows how I can make the flywheel stay on, lmk because some help would be gladly appreciated.
By Gwbarm
I bought this Eiger about a year ago it has been my runner while i worked on my other projects, except today it wouldnt crank, i suspect it is the petcock not letting fuel through. When i bought it it had a multitude of problems, but i just ignored those and rode it any way, put it on the back burner while i worked on my other projects with more serious problems, like stuck engine ,wiring harness ripped out, and wheels locked up. Got those all sorted out and since it wouldnt crank today decided it was time to refine this one. When i got it it had a bad Non OEM carb replaced it with a cheap aftermarket until i could find a descent priced OEM to rebuild, and have been riding it ever since. It also had a bad petcock, would only run on prime, neutral light didnt work, no brakes, which are a luxury anyway, but as im getting older luxurys are nice to have, so i guess i will fix those. I paid a little more for this one, $800 but he wanted $1500, because it ran and moved and most things seemed to work, and it didnt smoke, even with the bad carb. Generally 500 is my limit for a non runner, since this one ran i upped my limit a little. So i got it out of the shed before the mice got in it for the winter and started going over it today.
I would never buy a new camouflaged one because of what you see here, and it almost stopped me from buying this one, but it is what it is, not much i can do for that now, they did look nice when new, i am toying with the idea of replacing the plastics while i can still get them, but am not there yet, expensive.
I think the snorkel has got to go its not hooked up anyway. Looks like a perfect mouse house.
Similar Tagged Content
- 3 replies
- 899 views
Gallery Images
