Put in new carburetor, battery is good, 30a fuse in starter relay good whe I push start button  nothing happens except buzzing sound from batt. All lights come on. Won't start with pull cord either.
You probably have a bad connection somewhere, or a dud battery. The bad connection could be on the power wires/cables, or on an earth wire/cable. I think we should get that fixed first, then check the no start.
When you push the button and the buzzing happens, does the dash or warning lights go out ? And, if you turn the headlights on and push the button, does the headlight go dull ?
Can you tell us about the circumstances..  did it have the buzzing before the carb, or any work, has it been parked up or ridden regularly, have you had it long ? Anything else you can think of to tell us about it's history ?
battery good, connection is good, iv had that happen with a bad relay(soloenoid), the one with the 30A fuse, sometimes they just get old and stick, you might tap it gently with a hammer and see if it goes, or even the starter gets brush dust down in it and won't go , may try tapping that with a hammer , only after you make sure your battery is good. Mine was doing that when I would first try to start it, I knew I had put the wrong size battery cable on it when I was redoing the electrics, I used a lawn tractor cable thought sure it would be enough even though it was physically smaller, replaced it with OEM cable and never had another problem. My long winded point is check your battery cables also.
Oh one other thing the 2093 Kodaks will probably be lithium crystal powered.
  • Admin changed the title to 2003 Yamaha Kodiak No Start
    • By realpilot
    • By logray
    • By OldATVowner
