rear axle jam nut size
By noticon75
By realpilot
By cruteg8
Does anyone know the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way i put it high goes into reverse and vise versa I flipped it 180 but that put the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
By flyinbrian365
What's Covered:
By Admin
Topics covered include:
AWD and differential repair
Brake system service
Popular related searches:
Sportsman 570 wiring diagram
