  • Solution
If it has universal or cv joints then you will be able to see what bits turn and which don't.
If it's a solid axle (which I think it will be) then it's probably the hub the wheel attaches to that's stripped.
Edited by Mech
Yeah the parts diagrams are often easier to understand than the photos in service manuals.. though some service manuals do have exploded view diagrams too.
    • By pastorjeep
    • By geezer99
      I have an Axis 500 made by Hisun.  I uses a solid rear gearbox with no differential action.
      I would like to convert this to a true differential with locking ability.  I've searched all over trying to find a source with no luck.
      Has anyone done this before, or know of a source?
      Thanks,  Tom
    • By qcm413
      Hi,
      Thanks for a newbie on this site !
      i have grinding noise in my front differential. the front right wheel is turning and the left is try to turn but no movement and make sound like a gear broken. somebody have any idea ? not enough oil in diff ?
      thank
    • By DaveswMN
      Thanks for any thoughts.
