big bear 400 timing
Go to solution Solved by Mech,
I just want to clarify that i was doing the timing correct. I wanted to adjust the valves, so, I removed the spark plug, I removed that little black plastic cap on the side, then, i turned the engine counterclockwise until the "T" lined up with the small groove on the threads where that black cap screws in. Then i checked the valve clearances.
So, what is the "F" mark for?
I hope the "T" was the right mark to use.  lol
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By TomJulio
      My 1992 TRX00 recently stopped firing.  I understand this is a common problem. I have ordered an aftermarket CDI unit.    TJ
    • By TomJulio
