Ok...I'm gettin' me juevos ready to do an oir filter clean....
Went to my local harley/quad dealer and he had me purchase the No-Toil kit (Cleaner, Air Filter Oil, Rim Grease)
What I've read is that the No-Toil cleaner will NOT clean
other oils off air filters....just the No-Toil oil....
So, I've also read that others have cleaned their air filters
in the kitchen sink, used gasoline, or used flash solvent....
Looking for advice as I've mentioned I'm very mechanically
DECLINED! :wink:
I'm going to wash the air box seal in the sink and give it a good dry....
One more thing......No-Toil or Bel-Ray for filter oil?
Thanks!
-TD
USE KAROSINE!! NOT GASOLINE. karosine isnt as flammable as gas.
we jus soak ours in karosine,(we put the karosine in old dog bow. since mom is a cleanfreak) dry them with the air compressor, and spray some wd40 on em.then throw em back in.
Gasoline is usually more readily available and it works perfect. I soak mine in gas, ring it out and let it dry. I use PJ1 foam filter oil. A little axle grease on the rim and you're good to go. Of the 2 oils you mentioned I would go Bel-ray.
Ditto!!!!!! Been using Gas to Clean Foam Filters for Over 30 yrs.....NO PROBLEMS......
Good Luck!!!!!!
Oh,,,,I thought if you used a No Toil Filter you had to use the Oil and Cleaner as well???? Ill have to ask my Buddy.....He says he just puts his in the Washing machine :laugh:
Yeah...I got the No Toil kit....cleaner....filter foam....gasket lube.....
Still haven't gotten around to it.....worked late every night this week, and now RAIN!!!!!!!!!!!!!!
I do not have a garage....so I have to do everything outside.
BLEH!
-TD
I use SimpleGreen, it cuts the oil, doesn't stink or explode in my face. [OK I'm sensitive about that hehe.] I prefer K/n Spray oil- if you buy the kit with the cleaner in it, it's not a BAD cleaner, I just have better luck with simplegreen. If I were still married I would NEVER bring gasoline into the house....:realmad:
Its all done in the garage!
Yeah..im with bot...its all done in the garage.
Some of those oil cleaners dont work as well as the can says...
The oil is also not easy to get off your hands so use rubber gloves.
Use gas or simple green.
I love the smell of simple green after you use it to wash your quad and it heats up. lol :laugh:
Hubby usually leaves me to clean the filters :rolleyes:
you are so polite!
but every guy knows he'll use the kitchen sink if he can! don't try and lie now! LOL:wink:
HOPEFULLY NOT with gasoline- I was obviously not clear enough. sorries but I have known many people to do this, not including myself of course. REALLY. hahhaa
bot knows why.
    • By geezer99
      Well, I bought the Axis 500 sold at Lowes for $8999 a couple days ago.  This post will be about my impressions as I use, fix, and abuse the machine.  I will add to the post as I gain experience with it.
      Thanks to other posters on this site warning of new machines with loose hardware, one of my first actions was to crawl all over it checking fluids and connections.  Zirks were all freshly greased, fluids in engine, and gear boxes were up to level.  One of the little gas struts that help lift the bed to dump was dangling with only one end connected, and the other strut had not been fully tightened.
      The rear gearbox does not have a differential in it.  It is essentially a solid axle.  Tight turns on lawn will leave tracks, and turns are not as tight on pavement.  In my case this won't matter much, but if you plan to use it on a lawn, this will create tracks on turns.
      To check engine oil you need to remove both front seats and a plastic cover.  This according to the manual.  I'm pretty sure it can be checked with that stuff in place, either from under or above, but that remains to be seen.
      I am not used to a CVT transmission.  I am used to a clutch and multiple gears.  This one requires giving it plenty of gas out of the hole and then backing off to get it to shift up.  I'm sure I will get used to it, but I'd like to be able to take off quietly if I want to.
      The doors have bungie cords to act as springs to close them.  I removed the driver door so I would not need to fight the constant pressure to close.  Problem solved.  I will leave the passenger door as is.  Gotta keep the grandkids safe.
      Here is some stuff I like:
      I was concerned about there being enough torque to slowly climb a steep hill.  There is.  I will elaborate more on this when I've had it on my steeper trails.
      The display has dedicated lights to indicate status of gear position, low oil pressure, over temp, and a bunch of other stuff.  This helps a beginner with feedback that an action taken was successful.
      The sparsity of knobs on the tires dig in well on most surfaces.  I bet they wear out fast on pavement.
      The tilt bed has a tail gate that is easy to operate.  Much like early Japan pickups.
      Steering is responsive and little slack.  Remains to be seen how long to get loose since the u-joints are operating at quite sharp angles.
      Seats are pretty nice.  Will be interesting to see how long it will take me to poke a screw driver though them.
      Seat belts are included to hold grand kids in.  Won't go over 5 mph if both aren't buckled.  Yeah, it works to buckle them empty.  Doing this leaves the belt high on back, so you don't have to sit on it.
      Hauling it home, my trailer wheel wells were too close together to clear the tires of the UTV.  This required driving it off center a bit, with one set of tires inside the wells and one side driving over the wheel well.  Creeping over the one well required climbing a 10 inch vertical well.  The ability to lock the front axle differential kept both front wheels pulling as I drove the one side up and over the wheel well.  The guys at Lowes were impressed.  They won't touch any but an unobstructed flat trailer loading.
      tom
    • By kevinohio
    • By Rick Shropshire
      I recently picked up a  2000 warrior 350 and it doesn’t have the air filter box so I was thinking about using a clamp on filter directly on the carb.  Anyone know what I need to get or where I can find it? The one I ordered goes in the box and won’t fit directly on the carb.
    • By Need-help-with-quads
