2005 500 Scrambler acting up above idle speed need help
p5200
I added more fresh gas it sat one day now, it's acting up again. Before cleaning out carburetor it wouldn't idle good and had gas leaks from carburetor. Now it idles pretty good but, if I increase throttle speed at a certain amount it starts missing bad. I'm going to try and post a short video. Just about ready to give up on this thing.😒  you can see reflection perking in video.
Edited by p5200
You have cleaned the carburetor good so we know thats good now, just one thing i might mention, there is a jet down in a hole thats easy to miss when taking apart sometimes they are hard to get out, you might check that. The other thing is the mixture adjustment not the idle speed, it is in the front of carb on the bottom, sometimes there is a plug you have to take out to get to the adjusting screw. You might have done all this already, just thought i would mention it because it does still sound like fuel delivery. You could also try a new plug and check to make sure its got a good blue spark. Check all ignition wiring to make sure not corroded or loose. I couldnt see the video! I know it get frustrating at times, but too early to give up, we are here to help.
I got the jet out you mentioned. I sprayed all jets and everything out with carb cleanen then blew it all out with air compressor. I sure do appreciate all of your help! 👍
4 minutes ago, Gwbarm said:
Has this problem been previlant since you bought it or is it a new development.
It's new development. But it does sound noisier at the valve cover area.
The valve adjustment might have changed. If the valves have worn the rocker then adjusting them with feelers doesn't work well. The feeler doesn't allow for the wear because it just bridges across it and you end up with the feeler measurement plus the wear clearance. If the adjustment isn't right, things hammer and quickly get out of adjustment again.
There are a couple of ways of setting valves accurately. One is to use a dial gauge to measure the movement of the rocker, and the other is to check what the thread pitch is on the adjuster bolt, and then calculate how much of a turn it would take to get the correct clearance by backing out from from zero clearance. I set bike valves though by feeling the clearance and through a combination of feel and sound I know what the clearance is. Once the clearance is right, it stays right for a long time. If it's wrong it changes fast.. and that is true on most valve systems.
Other than the valves, read post #18..
Yeah i figured you had done that, but just thought i would mention it, the 2 turns out sound right , but i have had to adjust some i have worked on to 2.5 to 3 turns out to get it right. You may be OK with that. Back to the noisy top end, if these are known to have premature cam wear i would do as Mech suggested and try setting the valve clearance. There could also be some cam chain noise you are hearing, what type of sound it it rattling or a thud, or click click.
Most of it doesn't sound like tappets.. There are rattles and clunks..  haha.  It misses completely.   Does it run better if you open it up further P52 ?
I'd still recheck the valve clearance though. I've got the adjustment wrong before and they've gone out of adjustment in just a few minutes or riding..  It happens. And they can work tighter or looser.. Depends on the bike and how they were adjusted.
I'd also check the spark plug gap and the spark plug cap's resistance.
I snipped the wire going to the kill switch and right now it revs and is doing pretty good. Before I bought the machine, we had to unplug that black. We got spark 1 time and then nothing with black wire hooked up. I hooked it back later after operating kill switch a bunch of times and it then worked. I'm not positive, that was the problem I may still have a little moisture somewhere. I saw a new pull rope and handle I'm going to order and put on. I'll give it a go on the valves also, I'm sure they were probably never adjusted. I'm running it alot today just in case there is moisture still. I sure appreciate all of the help fellas! 👍
Yeah hopefully that is it. It might just be certain revs vibrations make something wiggle and short or loose contacts. Most switches on bikes come apart pretty easy. Just do it over a big tray so you don't loose little balls or springs. Clean the contacts and check the spring is firm and springy.
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By mga
      I Ran across this video today comparing an aftermarket to OEM Carb on Suzuki Vinson, thought it might generate some interest, it is quite long but informative.
    • By mga
