60" wide is too much. That's cool that they gave it the long arm travel. If I was to use our SxS for strictly racing then I MIGHT buy the RZR.
the trails we ride are all 70 inches wide(its posted on the trail map), expect for a couple spots. if i were to buy a utv it would definatly be the rzr. like i said before i love the outlaws new look. i wish they would make the exhaust look a lil better tho. make it look like the ltr's or something. ive also loved the fact that the outlaws(new and old) came frpm the factory with fox podium shocks. that pretty wicked to.
Yeah, the outlaw is sweet. The only thing I don't like about the RZR is there is no bed. There is but it's only 4" deep. When we go out we pile an ice chest, extra gas, and people in the back. The RZR would not meet all my needs. Other than that I think they are great.
    • By Rick Shropshire
      I’m looking at replacing rear brake calipers on both of my blasters. I was told that the only thing available was a hydraulic upgrade? I’d prefer the original. Anyone?
      I decided it was time to do the brakes on the Eiger, i got it a couple of years ago and worked out all the bugs got it running good and ignored the brakes. None on it ,front or rear. Decided to attack the front first no pressure on the master cylinder and screws were stripped out on the reservoir, took the banjo bolt loose and pure water ran out, glad i didnt wast time on drilling the screws out, pads were shot also. Pulled a couple out of my box o parts. One was for right hand so wouldnt work, the other looked fine until i opened the reservoir and full of white powder. Cleaned it out anyway and tried it, only would build up a minimal amount of pressure. So no go on that one. So ordered new master cylinder and pads, so now i have to hurry up and wait.
      On to the back they are drum brakes so i knew this would be fun, 20 year old machines that have been mudded and abused for that length of time nothing comes off easily. The engage shaft was froze solid from corrosion. Getting that out is easy but you have to get to it first.
      The center nut was supposed to be 30mm but it wasnt it was 27 the only size not in my large set, go figure,
      The previous owner decided it was a good idea to JB Weld the cover on making it near impossible to get off, had to chiesel it off.
      The mounting plate was a different story, nut was tight tight tight took my biggest impact two or 3 times hammering on it to get it loose after soaking all night in PB Blaster. Got it moving along the splined shaft easily but wouldnt come off, when it got to end of its run it would just stop, ended up using 2 24 inch pry bars one on each side, past the point of being gentle and it finally came off.
      Got to the drum and it came off easily a little suprised at that, it was full of mud and rust, i knew it was going to be bad because there was a snorkle on it when i got it, never buy one with a snorkle, they are highly abused to the machines limit, but i got it cheap .
      Finally got in there and no shoes left and a complete mess.
      Lots of mess to clean up.
      Got it looking a little better.
      Lots of cleanup later! Waiting for new parts.
    • By tds7
      Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
    • By bigbell
      Does any know what the stock jets are in the twin peaks?
      I bought the bike with a pipe on it and want to go back to stock setup.
    • By Winnem
      Hello.
      I've bought myself a Iron Baltic electric hydraulic plow lifter for my TGB, with a matching mounting kit. It was supposed to fit directly on my ATV. But I'm really not happy with the result. Had to cut off some of the cover under the atv, and still the angle didn't seem to be right in order to fasten the adapter on top. Also it touches the bumper and makes ugly marks.
      Is there anyone here with experience, or know a good solution on this?
