I was just looking at the "whats going on section" at the bottom of the main page and it shows 6 members and 24 guests on the site right now. My comment is to the guests who visit, you should go ahead and register! This is a great site, I've only been here a short time but I pop in here often and ALWAYS find something either entertaining,helpful or sometimes both!
C'mon in and say hello!
Yes...if you join now, you'll not only get membership in an elite group of ATV riders but, you'll be entered in to the "Win A Dream Date with Tom D!"
ACT NOW!
Operators are waiting!!!!!!!!!!!!!!!!!!!!!!
Bleh....
Tom D
*NOTE* In case Tom D is not able to make your Dream Date™, you will be escorted by a limping monkey with Tourettes Syndrome.....OOP! OOP! )($@*%&)(*&($ OOP!
ACT NOW!
Bleh....
Tom D
:laugh::laugh::laugh: OH MY UR CRAZY
Hey TX, my monkey is "Not for hire"
We need a "flinging poo" emoticon.....
THFFFFFFFFFFFFFFFFPPPPPPPPPPTTTTTTTTTTTT
-TD
While SOME might be Actual Guests.....Most of them are Internet Search Engines....
But I hear ya,,,,, Why lurk,,,,Just COME GET SOME!!!!!
how is an internet search engine a guest...???...:confused:
More commonly know as web spiders, bots, web crawlers.....
Basically, one computer launches a "program" that goes out and finds message boards and similar sites and tries to register......or gather meta data for their search engine....
Ever join a message board and asked to provide "secret answers" or to enter some character string before your registration is approved?
That's to prevent hacks/bots from joining....not just to annoy you! LOL!
-TD
-TD
ohhhhhhh i get it now:yes:
    • By BillR94
      Thank you for your time
      Bill
    • By 95kingQuad
    • By 97kingquad
    • By roggers
      Hi everyone,
      ·        Fast to download
      ·        Cover both heavy equipment and ATV models
      ·        Clear on licensing and safety
    • By wjmedic
      right front hub again
