This list is still under review and may be changed if We feel somthing needs to be changed/added/deleted..
Write Stock for anything below that is stock on your Bike.
White N/A for anything listed below that is not on your Bike
-Body-
Plastic-
Handguards-
Graphics-
Seat Cover-
Numbers-
Bar Pad-
Fuel Tank-
-Chassis/Control/Suspension-
Frame-
Steering Stem-
Hubs-
Handle Bars-
Throttle-
Clutch Lever/Perch-
Grips-
Nerfs-
Bumper-
Grab Bar-
A Arms-
Front Shocks-
Rear Shock-
Swingarm-
Axel Carrier-
Axle-
Brake Lines-
Axel Locknut-
Rotors F/R-
Rims F/R-
Tires F/R-
Stabilizer-
-Engine and Drive-
Cylinder-
Head-
Bore-
Stroke-
Displacement-
Carburetor-
Air Box-
Air Filter-
Case Vent filter-
Pipe or Silencer-
Clutch/Plates-
Gearing F/R-
CDI-
Kill Switch-
Cooling system-
-Other- please list.
-Pictures Limit 3-
  • Admin unpinned this topic
    • By gwares
      Price : 2500 EUR
      The Ultra Bee T offers the fastest acceleration of any road-legal electric motorcycle at this price-point, with the flexibility to deal with a wide range of surfaces. With its huge capability the Ultra Bee T will appeal to people looking for a great medium distance commuter, that’s also able to turn its hand to off-road riding and green laning.
      Everything works and new!
      We try to capture everything in photos for you.
      If you have any questions or need other photos, just ask, thanks.
      Send a direct message to make an inquiry or text:
      WhatsApp: +33 758 56 21 59
    • By bigbell
      Does any know what the stock jets are in the twin peaks?
      I bought the bike with a pipe on it and want to go back to stock setup.
    • By jannonballs
      What is this tube for?
    • By Freddie
      My first quad and I have a problem. I have a Kawasaki Bayou 300 1997. When I start it. It will go on high idle for about ten seconds before it goes down to low idle. It does this even when I don't touch the throttle or the choke.
      Also, when I give it some throttle and let go. It will come back to fast idle for about ten seconds before it comes down to slow idle. Therefore I have to wait for it to slow up before I can shift. The throttle linkage drops right back to the stop on the carb buy the rpms stay up for a while. If you have any ideas what might be wrong please let me know. thank you Fred
