By p5200
By dvs1961
By Frank Angerano
By Makj44
Hello I have a 1999 Honda 300 4w/drive and I just replaced the Oem carburetor with a aftermarket carburetor after installing the carb on the bike it started great and idled like new one but when I shifted into first gear and tried to move forward it died, I shifted back In neutral and the wheeler started easy again I let it set there to see if maybe it needed to warm up but when I shifted into first and tried accelerating it died again, I am not a use to working on it and would appreciate any advise thanks
By David Cameron
The small waterline insert for the hose that goes from the water pump cover to the thermostat housing has corroded off. I only need the insert on top and behind the thermostat housing that the hose goes over and can't find just the insert. It looks like it may be pressed in. I've have been told the entire motor housing needs to be replaced. The pic with the red line indicates where the hose and insert would be and the insert looks like the pic of the water pump Any ideas would be really appreciated.
