I have a 99 kodiak 400 4x4 that blows a fuse under the back left fender as soon as you attempt to put a new one in even with the key turned off. I'm having a hard time finding any wiring diagrams that show what this is for. And I'm trying not to have to tear into the wire harness. Any help would be appreciated.
It's more than likely that the short is not going to be inside the wiring loom, it's almost certainly a short where the insulation has chafed through until the wire is rubbing on the frame or engine.
The other likely possibility is that some electronic component is playing up, and the only electronic component that's connected to the battery all the time is the voltage regulator.
So.. disconnect the regulator and see if that cures the problem. Then, to save a lot of time, fuses and a possible meltdown in the wiring, get a headlight bulb, solder two wires to it, and push the wires into the fuse contacts. If the bulb glows you have a short. Then go through the wiring wriggling a little bit at a time, and gently lift it away from the frame a little bit at a time until the bulb goes out. Then check carefully around there for chafed insulation.. A good place to start wriggling wires is up around the steering head where wires move a lot when you turn the bars..
    • By Fonne
      Hi
    • By Arizona
      Just recently bought a dead 06 Eiger, Can someone post or send me a wiring diagram for it:?
      Need to check all wires, no power in most places, Cant seem to read the ones from online manual,
      too blury and cant tell wire color. Just too small. Thanks Az
    • By Peisledder
      Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
    • By quadnut20
      Just picked up this 2025 Kodiak 700 esp and was wondering if anyone has any suggestion on up grades i should look into  ?? I did a EPI clutch upgrade and put bigger tires on it but want to do more !!
    • By davefrombc
      I added a pdf of  the wiring of the various connectors used in vehicle socket  and trailer plug wiring to the  "Other ATV files"  section in downloads.
